Post Info TOPIC: Battery charger
Battery charger
I've Got a 80 watt solar portable panel
beside this one what is the best small charger to use when it home
an Ctek or an Projecta Pro-Charge Battery Charger 12V 2-8Amp
thank you allready for your replys
I recently bought a Ctek 15 amp charger, made in Sweden and seem to do a very good job .
Cant comment on the Pro charge, have never used one, though I notice its only rated at 8 amps.
Santa.
 Stay away from projecta, Period.
JC.
Ctek, no questions asked!
They are an 8-step charger. So there is a lot of control across multiple stages.
http://www.ctek.com/au/en/chargers/MXS%2010 is a nice unit
http://www.ctek.com/au/en/Product/Category?category=tank
Either of these units will work great for you.....
-- Edited by SaltyDog on Saturday 9th of March 2013 06:35:35 AM
Thank you all for that
Looking for an Ctek now
and @ Santa I tough it was better to charge slower than the fastway maybe I'm wrong
Morning John, as Salty Dog has commented, it seems these latest chargers control the charge rate constantly, they don't simply run flat out until they destroy the battery.
When my Ctek reaches full charge it drops the rate to a maintainance trickle, and I believe, can be left connected full time if needs be.
I bought the MXS15, seemed to be a good mid range unit. http://www.ctek.com/au/en/chargers/MXS%2015
Salty Dog, seems your second link was to a 24volt charger.
-- Edited by Santa on Saturday 9th of March 2013 10:03:27 AM
Santa.
Thanks Santa & Salty Dog for your help
I've seen an MXS15 for $249 is that ok
Sounds about the mark John, I paid $250 including postage from this Ebay seller
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=321023784549 they were good to deal with and shipped promptly.
-- Edited by Santa on Saturday 9th of March 2013 01:07:41 PM
Santa.
Cruising Cruize, for the purpose you have mentioned, a 5 would be more than enough and they are only $90 AUD
http://www.ebay.com.au/itm/CTEK-MXS-5-0-BATTERY-CHARGER-12-VOLT-12V-5A-5-AMP-REPLACES-XS4003-DEEP-CYCLE-AGM-/300824532033?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D6111500046838041147%26pid%3D100011%26prg%3D1005%26rk%3D2%26sd%3D321023784549%26#ht_3326wt_1220
Or even the trickle charger for $59
http://www.ebay.com.au/itm/CTEK-XS0-8-TRICKLE-BATTERY-CHARGER-12V-CAR-MOTOR-BIKE-ATV-REPLACES-XS800-COMFORT-/400347149377?_trksid=p2047675.m2109&_trkparms=aid%3D555001%26algo%3DPW.CURRENT%26ao%3D1%26asc%3D29%26meid%3D6111568268832992984%26pid%3D100010%26prg%3D1013%26rk%3D10%26sd%3D290821746802%26#ht_3070wt_1220
But for a more versitle unit, the 10 or 15 will be better.....
Buy right and one cry once ;)
-- Edited by SaltyDog on Saturday 9th of March 2013 01:48:06 PM
-- Edited by SaltyDog on Saturday 9th of March 2013 01:50:08 PM
Bahahah, i just checked, it wasn't even the correct link.... Doh :)
The 7 or 10 unit are great, i used one of the older 7000 units this week, its now called a 7.
My friend tells me he bought the 7000 off ebay for $78... personally i can not find them for under $250
will order an CTEK-MXS-10
"Ctek's MXS10 is a fully automatic 8-step battery charger that delivers 10A to 12V batteries from 20200Ah and is suitable for maintenance charging up to 300Ah. "
thats plenty my battery is only 100ah
thanks a lot for the support gentleman
regards John
Santa,
Don't want to rain on your parade but, Ctek are "designed/engineered" in Sweden, made in China.
Hurls
PS I have two, a 3.6A & 15A
Mark & Chris
You are only young once but, you can be immature for ever.
Hurls wrote:
Santa,
Hurls
 Just went out and checked, your absolutely right, hang about while I put my umbrella up.
Go's to show you should always read the fine print.ashamed
Santa.
Is there anything that's not made in China.
Walmart commissioned the largest container ship ever made. It sails empty from the US back to China !!!
 Cheers, Chris...
Be Warned, i just purchased a new CTEK MXS 5.0 and it destroyed a battery in 1 night!
A smaller 10Ah Motorbike battery, but still, it has a setting for the Motorbike size Batteries.
And a good AGM Battery that was working fine yesterday morning and now destroyed and only reads 10.23volts after having the CTEK connected to it for 24 hours.
There are also more stories like this on the net tool
Was it genuin ? So many copies out there on everything ..
