Post Info TOPIC: LED Lighting and Insects
I read that LED lights do not attract insects because they do not emit UV light.
Can anyone confirm this in real life ?
 Cheers, Chris...
They do attract insects but not nearly as bad as fluorescent lights, more like incandescent lamps. At least that's what I've found.
Merda tauris scientia vincit
I swapped our fluorescent tubes for led patch fittings and I still have to wipe out the same amount of bugs from the diffusers, just something you do.
Regards Jim
We've got a green 12volt Fluro on the side of the Caravan
Hardly any flies of mozies around when on
There are different styles of LEDs
Cool white attracts the insects and Warm white doesn't.
Brian
-- Edited by beiffe on Wednesday 13th of February 2013 08:59:54 AM
I have found they attract lots of little insects, but if the doors and windows are screened itcertainly helps.
The LED TV even attracts the big ones too, hard to clean the screen though. :)
Got to keep moving and as Hippocrates the modern medicine guru once said "Let food be thy medicine and medicine be thy food
Brian
 This is just the kind of tip I am currently looking for, beiffe. Thank you. We are trying to decide which LED brightness to use in various parts of our MH.
-- Edited by Shuttlebugs on Thursday 4th of April 2013 11:50:40 PM
Shuttlebugs
Colin 'n Susan
The information you find on this forum is priceless....
 Cheers, Chris...
