Post Info TOPIC: Gas Bottle Travel Covers
G'day one & all,
Does anyone know where I can buy Gas Bottle Travel Covers , have tried coverworld and every other web site to no avail !
Geoff & Bev 07 Millard Horizon Pop Top.  NP Pajero GLX DiD Auto
I've been looking as well.
Terry
Towing a Chief Arrow with a Colorado LTZ (All by Myself)
Why do you want to cover your gas bottles?
NeilnRuth
Agree with neilnruth, just change them out at every other service station/supermarket.  Also designed for overpressure, that is why they are date stamped!  Otherwise, just buy a cheap spraycan!
Never growing old, just getting dusty around the edges.
I had mine made by Shade & Shelter in Blacktown. I have had many items from them and currently waiting on an awning protector and a folding vinyl protector for the 4 awning rails.
You will need a sheet of masonite or similiar to just cover the bottles( oval shape) measure the height and give both to Luke or Lance tell them Dick sent you.
Dick.
-- Edited by littledick on Wednesday 6th of February 2013 09:37:32 AM
I'm interested in this one too. I remove the bottles from the front of my van when not using it and I'd like to not need to do this.
Merda tauris scientia vincit
If it worries you , tie a tarp around them .
TAJ
swaped a gas bottle bunnings put it in the cradle and it was half inch smaller
in diamenter would not clamp tight took it back ,,with a pair of outside calipers
and found two more were undersize
                       suenray
Yeh it annoys me too, the difference in dimensions. You would think a 9kg or 4.5kg bottle would be the same dimension but oh no they have make them different don't they!
As far as covers, I don' cover mine as when I am not in the playground the Avan is under cover.
we have a cover for ours and what I did was to buy some thick tablecloth covering from spotlight which is bought off a roll by the metre and made ours ,it has been on the bottles for over 12 months now with no sign of damage ,didn,t cost much either.
john & kay
 Exactly, all different sizes & they dont fit into the holders properly.
Besides that the swaps are far mor expensive, as if gas isn't already expensive enough.
I will not use these swaps for the above reasons. Bottles are desighned to be outdoors & only good for ten yrs so why worry about covering them.
JC.
JC.
 Bought new ones, so would like to keep them in good nick, my old gas bottles were a mess after 5 years & 50,000kms of travel.
Had a caravan for many years and never covered them even when travelling. Is it really necessary? Is there any danger not having them covered? Just curious because we are heading up some rough roads soon and don't want any problems. Cheers
C.R.A.F.T.Y OL' BUGGAS
Coxy45 wrote:
G'day one & all,
 Try a canvas shop. There are always canvas stalls at our caravan show here in Adelaide and they sell them.
 Gail
"Started wandering and don't wish to stop!"
The gas bottles are smaller because they ARE smaller. We had to get a new one in Broken Hill (at a service station not Bunnings) and the 9kg bottle is now 8.5kg but costs the same. Hubby had to work hard to screw the holder in tighter then ended up added a small chock of wood to help.
NeilnRuth
 Only reason to cover them is cosmetic, no other reason.
I have been using the swap & go ones from Bunnings .. they seem to have reduced the prices recently.  Used to be round $27 but close to $20 now I think, which is about what t he local Camping shops charge for a refill.  BBQ Galore used to be the cheapest but the local store closed down & now too far to drive.
But the bottles at Bunnings are almost all rated at class 4.  Caravan bottles are supposed to be rated as class 2 I believe.
As well they are often out of date & I couldn't find any re- tested markings.
I go through the bin and select any class 4's that are inside the test by date.  Size is not a problem with my clamps.
My old Jayco Westport came with a fibre glass cover over the A frame mounted bottles.  Have fitted a padlock to mine.
A friend has a piece of string cut to the correct diameter for his clamps that he uses to select bottles.
Brought my gas bottle cover from BCF. Under $50 ..we also padlock our bottles.
Time To Sleep Later In Life.
