Post Info TOPIC: 12v Air Compressor
12v Air Compressor
I had a thought this morning, I wonder if I could hook up a Anderson Plug to the wire on the above mentioned pump, use my  6B&S extention Cable plugged into the Anderson Plug on the back of the Prado.
So I soldered the wires into a Anderson Plug, hooked it all up and it worked like a charm. Now I don't have to worry about alligator clamps or the cig lighter plug that did't work anyway due to voltage drop.
I'm a happy camper.
I put a comment in Techies Corner as well.
edit...sorry not sure what whent wrong, I meant to put this in the hints section
-- Edited by Dougwe on Sunday 3rd of February 2013 06:55:28 PM
That's a much better set-up than the clips and as for cig lighter sockets on air compressors, nuff said!
Merda tauris scientia vincit
DITTO.
JC.
gst
Great idea Doug Ill use that one.
Regards Greg
I have done what Doug has done with the Anderson plug connection but have also fitted an Anderson plug to the aligator clip lead.
Regards Jim
I have run an anderson plug to the side of my van which is hooked up to the caravan smart charger, so now with another long lead with anderson plugs on both ends I can charge my dual battery in the car when I have power
I also have a smaller lead with alligator clips on one end so I can also charge the main car battery if needed
I saw this on a van at Mareeba and works well
Ken
DUN WURKUN
in my forester i hard mounted the compressor and run air line to the front and the back with taps then just had hose with gauge im doing the same on the colorado consatena
dibs
gdyble
