Post Info TOPIC: 15 amp outlets revisited
Hi Boothie
As you say" Yes, I know it is illegal, but can I get away with it?"
It is illegal no matter how where you use
Anyone suggesting it is ok is promoting an illegal act
I cannot advise other wise
Best advise is buy an "Ampfibian adapter} fully legal ,& safe ,for that very purpose
-- Edited by oldtrack123 on Sunday 6th of January 2013 11:10:32 PM
I have done searches and read all posts I could on recharging 12 volt batteries and running my fridge on gas whilst I have my van plugged into 10 amps.  Set the scene, retiring later this year, bought a van before Christmas, went interstate over Christmas, wife and her family thing.  For those fishos, I joined the metre plus club on Snapper fishing Tapley Shoal, SA.
Got home with a couple of weeks to go before that dreaded 4 letter word, work.  I want to give the van a shakedown run and I need to charge the battery.  Now the  question is, not running anything else but the battery management system in a Jayco Sterling apart from the fridge on gas, can I get away with a 10 amp circuit.
I have done the basic sums and everything says that the amps and ohms and as long as the air conditioner is not turned on will not trip anything.  Yes, I know it is illegal, but can I get away with it?
Never growing old, just getting dusty around the edges.
KFT
G'day Boothie,
Mate the question really is should you even try it? it is illegal for many very good reasons which can be quite technical.
I would suggest the best way to do what you are looking to do is to plug a 10 amp lead directly to the battery charger which should be plugged in somewhere near the battery. You can use a normal 10 amp lead to do that and all is quite legal.
Try that and see how you go.
frank
Avagreatday.
jimricho wrote:
The battery management system plugs into a normal power point in a nearby cupboard (you're probably aware of this) so Frank's solution is simple, legal, safe, and involves no more expense than a standard 10 amp extension which I dare say you have anyway.
Hi Jim
Sorry, but not quite legalno
A lead should not be taken through a window or doorway, for safety reasons[especialy when metal frame work is involved as in most vans Motor homes etc]
 Yes , I KNOW it is a common practise
-- Edited by oldtrack123 on Monday 7th of January 2013 12:57:26 PM
If you wish to connect the whole van to the power an alternative to the Ampfibian is have a licensed sparky install a 15 amp outlet, maybe in the meter box if this is practical.
Why the hell am I helping someone who joined the metre plus snapper club! No, I'm not the jealous type! (Not Half!!disbelief  wink)
Merda tauris scientia vincit
Have you got a pic of the snapper?
 Hi Boothie, as you state "yes, I know it is illegal, but can I get away with it"? No, you cant, but the simplest way to meet your needs and keep it legal but more importantly safe for you and your family is to install a 15amp plug.
To buy a Amphibian 10/15amp plug at Bunnings is around $150. I have just 3 weeks ago had a sparky install 2 new generation smoke detectors and wire a 15amp power point with circuit breaker to meter......all up cost $275.00
My insurer has been notified and all is accepted as meeting their criteria; I can run the van normally from home if I so desire.
Do it right and sleep with peace of mind.
ozi2
The Happy Helper
 Oh, Bill12 - stay on topicbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrinbiggrin You have a one track mind!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Fish, fish and more fish!!!
jules
(Ben, aged 10)
I got a great tshirt for xmas- It says "old fishermen never die- they only smell that way!"..............
Just leave the bloody door open for crissake! it only takes a few hours or less to top up a battery! wink
I must confess in my almost 70 years on this planet I have not for every microsecond of those years at all times obeyed every law on the state and federal statute books!
naughty me!wink
(edit to remove typo, must not leave any typos!wink)
-- Edited by jimricho on Monday 7th of January 2013 07:58:38 PM
 Hi Jim
That  same excuse could be used for the illegal adapterno
But in those few hours the door / window may be slammed on it
Simply NOT A SAFE way
and is  the SAME situation  of running a lead from  a power point IN THE van to the outside which should not be done
IF IT MUST BE DONE care should be taken to protect the cable from damage by a rigid surround in that area
What I do not understand is the reluctance of some to do it the SAFE way
It is hardly likely to be only a one of occasssion
 So the Ampfibian has an ongoing use whenever only a 10A source is available
 The rules cannot be expected to cover EVERY situation SOMTIMES  the overal INTENT needs to be understood
Of course some look for every possible loophole to avoid the intent
-- Edited by oldtrack123 on Monday 7th of January 2013 10:27:48 PM
KFT wrote:
oldtrack123 wrote:
Hi Jim
 I dont recall seeing anywhere that actually made it illegal, the blokes building the van in the first place would have had to do it to run their power tools.
Hardly the same situation!!
Workshops should have safety procedures of their own under workplace health & safety
They do not have the Missus or the kids who may slam the door /window on the  only lightly protected cable
-- Edited by oldtrack123 on Monday 7th of January 2013 10:23:11 PM
A dirt track maybe?wink
I thought fishing was the topicbiggrin, The OP mentioned a metre long snapper! that alone makes fishing the topic!biggrin What's the stuff about power cords doing here!biggrinbiggrinconfuse
(for those who hid behind the door when sense of humour was being handied out I'm only joking)
KFT
oldtrack123 wrote:
Hi Jim
Avagreatday.
I am sorry that I have obviously opened a can of worms, and that yes electrical standards need to be obeyed.  I have now discovered that I have a 15 amp oulet in my garage, the place used to be owned by a sandblaster, answers my question about the built up garden beds filled with sandy soil.  And before anyone gets on and tells me that it is actually 15amp as there should be no space between the numbers and description of the unit of measurement, I would like to point out that I have a picture of snapper that may be the metre long fish caught but I can't upload it, keeps telling me it is not a picture!
The battery is on charge, the airconditioner is on and I am like a kid cause this is going to be the first night I get to sleep in the van, sort of like that first time in a tent, even though it was in the backyard, and even though the caravan is the driveway.  I am starting to feel young againsmile
The shakedown will occur if I can get the missuss geed up!  A few days at Colac Colac or there abouts.  But the Peter Pan in me is camping out tonight!
 The file size of a fish that big is probably too large to upload! LOL!  A mate of mine once went overseas to go fishing and he caught one that big that he had to pay excess baggage on the photos!
Well I am guilty, I have been charging the battery with a 10 amp lead for a few months , I switched it off after reading this topic. Now I push the battery charging plug through the little flap to the out side.( A Van ) I hope that this is legal'
Hans
Hi Hans
That sounds like you are using the same entry point as the fixed 15A cable
All good & legalwink
 Peter, to put it simply ,yes.
Hans
Back to fish, I posted photo in the General Forum under My big snapper!
Back on topic.
Have an electrician coming over tomorrow to install a 15 amp outlet and circuit breaker in our meter box, pretty straight forward job and will now be not only legal but safe.smile
Santa.
