Post Info TOPIC: Water Leak.
Water Leak.
Hi Curl, while my water leak was a bit different. While tracing mineI found that it was nowhere where it came out into the van. It in fact was about 2 meters away but traveled before presenting its self. You may want to consider that. Trust you find it soon. Water leaks can cause so much heart ache. In spite of it all trust you have a great christmas. Brian
-- Edited by briche on Monday 24th of December 2012 01:14:08 PM
Hello all.
I might be in the wrong place to ask this.......but perhaps someone can advise.
Had 100mm of rain last night and yes..........I have a water leak.
I have a 2009 "Jayco Sterling" and have a water leak through the light fitting on the Silver cover strip in front of the overhead Cupboards above the sink. I just thought that perhaps someone with the same Van might have been down this road before and might save me a bit of time to locate the problem.
But, would appreciate all help.
Thanks.
Curl.
Few, not a good spot for a leak Curl, I hope you get it sorted sooner than later. Keep safe while checking it out and fixing and,
We had a water leak recently that was caused by the cover on the TV antenna (where the antenna is attached to the van) having come loose. Fixed in 2 minutes with a bit of sealant.
I am still working on my water leak. Turns out it isnt one, but several, and I have found that you have to think outside the square, as previously stated water can travel some distance especially if the van isn't sitting level. Good luck :)
Where the water comes in is not where gets in. It could be where the roof joins the walls, or a join in the roof, or at a hatch, the aircon, the TV antenna, and runs to the light fittings. It doesn't seem to matter if the van is aluminium or fibreglass sheeting. It's a good insurance to run Sikaflex, marine and auto into all joins when the van is dry.
Check the amount of lean/fall the van has, from the high point to the lowest point.
You do need to seal the leak from the outside, BEFORE the water get in. It won't do the van any good to seal the light fittings, because the water will still be up there somewhere.
Good luck with that one.
I found the water ran down the underside of the aluminium sheet where it folds over and joins the next sheet and the front corner. It ran to the front of the van and into my wardrobes. Big job that one.
Transport has no borders.
we had a leak in the ensuite ceiling thought it was coming from the right corner NO from the left and runnung to the right and centre and into the light, we claimed flood damage from our insurance it ruined the ceiling we had a new ceiling fitted by B&B caravan repairs in Brisbane they had to lift back end of the roof to fit the new ceiling made an excellent job cost insurance $2000.00 we have a Sterling 23footer
Neil
you are never too old to set another goal or to dream another dream
I had my watermarks assessed and the damage done to the interior, but no go with the insurance. I fixed the leaks, and the water marks stayed. The awning was also brittle and fragile, but no claim there either. I've replaced the awning earlier this year.
Funny thing insurance - NOT!
we didnt get our insurance that easy we had to fight the assessor tooth and nail to get the it fixed on the insurance ihave since changed insurance companies you get what you pay for with insurance and be sure to read the small print
Neil
Well, I did'nt really locate the leak. I suspect that it was entering in through a corner of the Hatch that showed some moisture still present after 2 Days of drying out. So to be sure, I applied Silicon all over the sealed areas again. Just need to wait for the next Downpour now.
