SmartBar Camp Creative
Post Info TOPIC: Battery power
Battery power
Can you use your battery while you've got your solar panels charging them ????
or do you have to disconnect the solar ??
The Master
Hi John. Yes you can use them at the same time. Some leave the solar panels connected all the time in their camping spot and use it as necessary.
It was all happening at Greens Lake.
Hope you both are well.
Happy Wanderer
Don't worry, Be Happy!
 All panels mounted on roof tops are permantly connected to the batteries so the answer is yes.
JC.
Thanks for that
was not sure the voltage is always a bit more when on charge
In fact the more power you use while on charge (compared with when off charge), the better it will be for your batteries.
 HI
And by that Peter means "make hay while the sun shines"
 HI
 Or crack out the slushy machine and make frozen Margaritas....... hic.
Hi Troopy
We are in fine form tonight
Not too many frozen Margaritas ,nowsmile,
Even though making them did not pull the battery down
