Post Info TOPIC: Experimental LED
Experimental LED
Followng a discussion at Greens Lake a few weeks ago, I have been ivestigating different types of LED lights.
I have just received a 5W Rectangular LED, it is a really good source of light, and power consumption is low.
Dimensions:  100mm * 9.5mm * about 2mm high. The LED material is about 2mm shorter and narrower that the aluminium carrier.
It generate a clean bright light, slightly softer than the stark white LEDs that are common.
I used a battery at 12.2v and it consumed 2A, resullting in a 2.4w of power consumption. It also generates a small amount of heat.
I sourced this example from DX.com (cheap but slow online source, with lots of toys).
Discovery 4,
Retreat Brampton
sorry but i dont want to be smart
please help people ,5 watt is as far I know not 2 amp or do I have it wrong
what price are they btw
and are they as bright as an 8 or 9 watt ???  fluro
John, you are absolutely correct, when I went back and re measured it it was 0.2A, so cunsumption is really 2.4W at 12V.
Yes it is bright, I tested it in a room about 2m by 3m, with a white ceiling, I used it as an up light from the top of a bookcase, and the reflected light off the ceiling was enough to read comfortable across the room.
 I would say you could light the living and sleeping space in a 20ft van with 2 or 3 units used in a similar manner (pointing up), thus a total power drain of about 0.6A.
I realise that it is advertised as 5W, and draws 2.4W, but its light output is about equivalent to a 65W globe in the old incandescent style.
Discovery 4,
Retreat Brampton
The Happy Helper
Deals Extreme are great for gadgets - recently purchased three 12v chargers for our computers - only needed two, but got a discount for buying three, with free postage - arrived in about two weeks - work a treat - the three were $35. One thing though, the supplied connection to the computer socket didn't fit my HP, but I swapped mine with Yeoelven, and that works well.
jules
(Ben, aged 10)
Master's the  new h/ware store has 1.5 Watt 12v Led globes which fit into the standard 12v M16 fitting for only $8
Bugger if I can find them on there website
try this web address, Cruising Cruze http://www.masters.com.au/lighting-fans/light-globes/led-light-globes
I did a google search on it
Hope it helps
ColB
Landcruiser 100 series towing a 9.5m Coromal Capri 780
Thanks Col for looking it up mate , but they were not the ones I meant
the ones from deal extreme I wanted
Regards John
