Post Info TOPIC: Jayco Recall Advice
Jayco Recall Advice
This may be of interest to Jayco owners - check to see if your chassis number is in the list.
JAYCO has issued a nationwide recall of more than 700 caravans and campers after fears axles could slip out of alignment.
According to a company safety alert, axle U-bolt nuts on vehicles with chassis numbers between P12118 and P81107 may have been installed with incorrect torque settings.
In a statement, Australia's biggest manufacturer of recreational vehicles said this could result in suspension springs moving and affecting the axle's alignment.
"This may cause the 'van to be less stable than normal while towing," Jayco warned.
Owners of suspect RVs are urged to contact their nearest Jayco dealer or service agent to arrange for a free inspection and rectification if required.
The work could also be undertaken at Lube Mobile centres.
In a letter to owners, Jayco's national service manager Paul Morgan wrote: "We sincerely apologise for this inconvenience, however it is necessary to ensure the safe operation of your Jayco."
Owners experiencing any problems or difficulties in making arrangements with Jayco dealers or service agents, should contact the company's service department on Free Call 1800 331 601, or 03 8792 2136 if in Victoria.
Chassis numbers of affected campers and caravans are:
P12118 P13406 P13437 P13504 P13562 P13593 P13680 P13709 P13742
P12156 P13407 P13438 P13505 P13563 P13594 P13681 P13710 P13743
P12207 P13408 P13439 P13506 P13564 P13595 P13683 P13711 P13744
P13383 P13409 P13440 P13507 P13565 P13596 P13684 P13712 P13780
P13384 P13410 P13441 P13508 P13566 P13626 P13685 P13713 P13781
P13385 P13411 P13477 P13509 P13567 P13627 P13686 P13714 P13782
P13386 P13412 P13478 P13510 P13568 P13628 P13687 P13715 P13783
P13387 P13413 P13479 P13511 P13569 P13629 P13689 P13716 P13784
P13388 P13414 P13480 P13513 P13570 P13630 P13690 P13717 P13785
P13389 P13415 P13481 P13514 P13571 P13631 P13691 P13718 P13786
P13391 P13416 P13482 P13515 P13577 P13632 P13692 P13725 P13787
P13392 P13423 P13483 P13516 P13578 P13633 P13693 P13726 P13788
P13393 P13424 P13484 P13547 P13579 P13634 P13694 P13728 P13789
P13394 P13425 P13485 P13548 P13580 P13636 P13696 P13729 P13790
P13395 P13426 P13486 P13549 P13582 P13637 P13697 P13730 P13791
P13396 P13427 P13488 P13551 P13583 P13638 P13698 P13731 P13792
P13397 P13428 P13489 P13552 P13584 P13640 P13699 P13732 P13793
P13398 P13429 P13491 P13553 P13585 P13641 P13701 P13733 P13794
P13399 P13430 P13492 P13554 P13586 P13642 P13702 P13735 P13795
P13400 P13431 P13493 P13555 P13587 P13643 P13703 P13736 P13796
P13401 P13432 P13499 P13556 P13588 P13644 P13704 P13737 P13797
P13402 P13433 P13500 P13557 P13589 P13645 P13705 P13738 P13798
P13403 P13434 P13501 P13559 P13590 P13646 P13706 P13739 P13834
P13404 P13435 P13502 P13560 P13591 P13678 P13707 P13740 P13835
P13405 P13436 P13503 P13561 P13592 P13679 P13708 P13741 P13836
P13837 P13864 P13895 P13944 P18118 P18152 P18221 P18271 P42177
P13838 P13865 P13896 P14083 P18121 P18153 P18222 P38036 P42198
P13839 P13866 P13897 P15103 P18122 P18154 P18223 P38046 P42199
P13840 P13867 P13898 P15151 P18124 P18155 P18224 P38047 P42200
P13841 P13868 P13899 P15155 P18125 P18156 P18225 P38060 P42201
P13842 P13869 P13901 P15171 P18126 P18157 P18226 P38061 P42202
P13843 P13871 P13902 P16189 P18127 P18158 P18227 P38083 P42203
P13845 P13872 P13903 P16190 P18129 P18159 P18228 P38084 P42204
P13846 P13873 P13904 P16227 P18130 P18160 P18229 P38089 P42221
P13847 P13874 P13905 P16229 P18131 P18198 P18230 P42144 P42222
P13848 P13875 P13906 P16288 P18132 P18199 P18231 P42145 P42223
P13849 P13876 P13907 P16290 P18133 P18201 P18232 P42146 P42224
P13851 P13877 P13908 P16291 P18134 P18202 P18258 P42147 P42225
P13852 P13878 P13909 P16304 P18135 P18204 P18259 P42148 P42248
P13853 P13879 P13910 P16319 P18136 P18205 P18260 P42149 P42249
P13854 P13880 P13911 P16321 P18137 P18206 P18261 P42150 P42250
P13855 P13881 P13912 P16369 P18138 P18207 P18262 P42151 P42251
P13856 P13882 P13913 P16370 P18139 P18208 P18263 P42152 P42252
P13857 P13883 P13935 P16371 P18140 P18209 P18264 P42153 P42253
P13858 P13884 P13936 P16373 P18141 P18210 P18265 P42154 P42254
P13859 P13885 P13938 P16394 P18142 P18211 P18266 P42155 P42270
P13860 P13891 P13939 P16452 P18143 P18212 P18267 P42156 P42271
P13861 P13892 P13940 P16456 P18149 P18218 P18268 P42157 P42273
P13862 P13893 P13941 P18116 P18150 P18219 P18269 P42174 P42274
P13863 P13894 P13942 P18117 P18151 P18220 P18270 P42176 P42275
P42276 P44105 P44188 P44266 P49312 P49425 P49519 P49586 P49663
P42277 P44116 P44200 P44267 P49322 P49426 P49520 P49597 P49664
P42278 P44117 P44201 P44268 P49323 P49427 P49522 P49598 P49665
P42301 P44118 P44202 P44290 P49324 P49428 P49523 P49599 P49666
P42302 P44119 P44203 P44291 P49325 P49429 P49546 P49600 P49667
P42304 P44125 P44217 P44292 P49326 P49431 P49548 P49603 P49668
P42305 P44126 P44218 P44293 P49327 P49433 P49549 P49604 P49669
P42328 P44127 P44219 P44294 P49340 P49434 P49550 P49615 P49670
P42329 P44128 P44220 P44295 P49341 P49435 P49551 P49616 P49671
P42330 P44129 P44221 P44296 P49360 P49436 P49552 P49617 P49672
P42331 P44130 P44222 P44297 P49361 P49454 P49553 P49618 P52192
P42332 P44131 P44223 P44298 P49362 P49455 P49565 P49619 P52193
P42334 P44132 P44224 P44299 P49364 P49456 P49566 P49620 P52194
P42335 P44134 P44253 P44300 P49365 P49457 P49567 P49621 P52195
P42336 P44135 P44254 P44301 P49366 P49480 P49568 P49622 P52206
P42337 P44137 P44255 P48035 P49367 P49481 P49569 P49623 P52207
P42338 P44138 P44256 P48053 P49368 P49482 P49570 P49624 P52208
P42339 P44180 P44257 P48055 P49378 P49483 P49571 P49625 P52233
P44098 P44181 P44258 P48085 P49379 P49484 P49579 P49635 P52234
P44099 P44182 P44259 P48086 P49381 P49485 P49580 P49637 P52241
P44100 P44183 P44261 P49305 P49382 P49486 P49581 P49638 P52269
P44101 P44184 P44262 P49306 P49398 P49505 P49582 P49640 P52270
P44102 P44185 P44263 P49307 P49399 P49506 P49583 P49641 P52271
P44103 P44186 P44264 P49309 P49400 P49507 P49584 P49642 P52272
P44104 P44187 P44265 P49310 P49402 P49509 P49585 P49643 P52298
P52336 P80713 P81102
P52360 P80714 P81103
P52361 P80715 P81104
P52362 P80716 P81105
P52364 P80717 P81106
P52366 P80718 P81107
P52384 P80727
P52385 P80728
P52412 P80729
P52413 P80824
P52414 P80825
P52415 P80826
P52416 P80827
P52417 P80828
P52425 P81015
P52426 P81016
P52427 P81017
P70765 P81018
P71243 P81020
P80498 P81021
P80499 P81022
P80500 P81024
P80663 P81025
P80711 P81026
P80712 P81027
Thanks John useful info
Thanks RL, checked our chassis #, all ok.
Cheers,  Gerty. ... at home
Thanks RK, ours is okay as well. Glenda
-- Edited by golivers travels on Sunday 2nd of December 2012 08:23:48 PM
Glenda and Gary Oliver 2010 Pajero with 2008 19 ft Jayco Sterling Our Blog: http://www.birdshootaustralia.blogspot.com http://www.birdshootuk.blogspot.com.au
Many thanks for the advice. This is the only place I have seen this.
Goodie
