SmartBar
Post Info TOPIC: Automatic oil flush
Automatic oil flush
Just had the pan removed and transmission oil flushed on my 2008 diesel auto Prado , Is there a general rule for this can't get an answer on how often this should be done , The Auto transmission  workshop that did this for me said you should have your transmission serviced yearly when towing a caravan . this work that has just been done has made a big difference to to the gear changes much smoother
Thanks for that Brickies. I am about to organize a service after being away for 9 months in Qld so I must make sure they do that'
Brian
When I was in my 20s an old guy I knew (no, not as old as I am now) told me of his younger days selling cars. He told a customer that the car of interest had an "automatic oil changer", all you had to do was add a quart every 100 miles! He sold the car!
Merda tauris scientia vincit
Maybe we still get told the same things in a smarter way , Jim do you get your auto serviced or are you manual
every 20 000km when towiing and more often if your transmission temps are getting on the higher side of things. You may say that oil is expensive but it is cheap insurance compared to some of the horror cost of rebuilding a later type outo.
blaze
 Mine's a manual Terry.
I had my transmission serviced just prior to the trip to north QLD by Marco's in Penrith where they service a lot of Taxi's and specialise in transmissions, their recommendation if doing a lot of towing is every 20000 klm they also suggest increasing the size of the transmission cooler.
David they put synthetic oil has he said it better for towing the Prado holds 15 lites , he said if you are towing to get a service at lets once a year service cheaper than new automatic transmission , I also can feel the Auto responds much smoother and quieter
