SmartBar Mackay Festival of Arts Floriade Darwin International Film Festival
Post Info TOPIC: smelly toilet
smelly toilet
Hi all we have a toilet in our van that goes smelly after a couple of days we are useing the green tablets so we can empty it into a septic tank
our toilet does not have a place for the pink liquid that helps with that ,we only add the tablets
what can we use to stop this please any ideas would be a great help
A few drops of eucalyptus oil every couple of days does the trick .
I have been using nappysan for 6 months - no problems :)
The Happy Helper
The CHEAP home brand nappy soaker works really well - had some of the "genuine" one, and the loo got smelly very quickly. Have heard of people having a spray bottle with either eucalyptus or disinfectant (diluted) and spraying the bowl with that -
Don't like the chemical stuff that you can get - all you smell is the chemical when you come in the door - yukk!!
jules
(Ben, aged 10)
I agree with the above,  cheap brand Nappisan, and a little eucalyptus oil, seems to work well ''so far''
The only time i thought that combination had let me down ? It turned out that i was parked next to a ''wombat'' hole biggrinbiggrin
IF IT IS TO BE !! IT IS UP TO ME !!!
Master (of Mischief)
 wombat poo does not smell, get down on the ground and have a sniff next time you see any, in other words my sxxt does not stink biggrinbiggrin
Wombat wrote.
See !! there you go again, ''Assuming'' that it was YOUR wombat hole ?? biggrinbiggrin
Michelle is right ! wink I keep trying to be nice, and you and Dougwe twist my comments to try and get me into trouble biggrin
dazren wrote:
Wombat wrote.
 I NEVER assume cos it makes an ass out of u and me, delete the black text and you will see what I mean biggrinbiggrin
BG would never aggree with you biggrinbiggrin
We would not let you park next to our wombat hole.
Oma
Home berand napisan is definately the fo but be careful, only a couple of drops of Eucalyptus. Have been using this for about 6 years now.
Margaret having used a hire MH recently we ditched the stuff that they had given us for the napisan and eucalyptus oil option also. I am so glad that I am a member on here and had read this option previously. For 11 days we only had one day where the toilet a little smelly and it was when the boys had decided to be lazy and put the chemical sachet in, instead of the home made stuff.
Sharon
Dream it, believe it, live it.
4WD with a ford ranger. The possibilities are endless.
On reading up on eucalyptus oil it seems it has antibacterial properties so wouldn't this mean a nappy wash and eucalyptus oil mix could be not used in a septic tank?
