Post Info TOPIC: pop top campers vs hard top campers
RE: pop top campers vs hard top campers
I get in underground carparks with my hiace with a 2.1 metre clearance.
Janette
if any one is travelling my way (shoalhaven nsw) and has a pop top campervan,
Id appreciate a visit.. too see how one would fit thru my carport...
If it were a simple little carport id pull it down but unfortunately its part of the house.no..
The Drewsterz my band site
Milo Online  my personal site
Just wondering too.
What would you do for a tv antenna on the van ?
Are those portable ones any good?
Duh
milo wrote:
so i got 7 feet clearance when the roller door is up which is roughly 2.1 metres...
i got almost 8 ft if i take off the roller door...
 Milo,
On the sides of the Roller Door are a couple of tracks, they have a couple of stoppers on either side where you roller door stops at the top.
You may be able to raise the roller door opening a bit by undoing the track fixtures and moving your stoppers up, or depending on your door may need to raise the runners a bit.  You don't have to remove the roller door to do this.
I raised mine for my campervan which needed a 2.1 clearance to the top of the pop top as mine wasn't high enough, worked ok for me.
Saves having to remove the roller door completely.  Be sure to allow for any sloped driveway coming into the carport, this could make a difference of the clearance needed depending on the angle.
Ask you handyman you used for your fence if you're not sure how to do it, he may be able to help you.
-- Edited by Duh on Monday 29th of October 2012 03:24:29 PM
just measured with the door this time , 2.3 metres is the hight clearance i need
thanks didn't know you could raise the roller door
Duh
 Yes, you are actually raising the part of the door that closes down so that it goes up higher, bearing in mind that you can only go up a few centimetres to the bottom of the "roll" by adjusting the side runners like I described before.  All this does is let the door bottom (or top when you have it up) go up further giving you a little extra height.  I hope that makes sense.
Wouldn't be enough for a fixed high top campervan though, only a pop top when in the down position.
thanks again,ill have a yarn with my handy man when i can ..
