Post Info TOPIC: Seeking advice on generators...
 Greetings one and all,
 This is my first post here and I have been eagerly awaiting my membership to be approved so as I can seek some of your collective expertise :)
 Ok, so its generators I want to ask about...
 I have searched and done a bit of reading on the topic and my questions are about small petrol generators. I have purchased a basic 2 stroke 240 volt one for battery charging and as a bit of insurance. So here goes:
 First up running in 2 stroke generators.
I have found differing advice on this subject, actually two general sets of opinions 180 degrees opposed:
The manual and many forums suggest a slow run-in period with a light load. This makes general sense to me, to gently and slowly run it in. It is the approach I would normally take.
However! Some forums suggest the absolute oppposite. Running the brand new generator HARD with a solid, near capaicty load to "seat the rings".
 Opinions?
 Secondly, a quicky:
 Does running a generator without a load do any damage?
 Many thanks!
-- Edited by Gordo65 on Sunday 16th of September 2012 07:31:57 PM
-- Edited by Gordo65 on Sunday 16th of September 2012 07:55:22 PM
Running the brand new generator HARD with a solid, near capaicty load to seat the rings
Yep run it in like you will use it and add abit of extra oil to the fuel
Im informed it does
Something to with the electrics
no load equals carboned up ports and fouled spark plug. Run in proceedure is really a thing of the past when we made the big end bearings and scaping them to correct tolleremces amd grinding the ends of the rings so they had a few thou gap for cleanace. Just use it as intended with a slightly lighter load for a 1/4 hour with a slightly oil fuel mix as previously sugested.
blaze
ps remember the fellow campers when using
Ah, glad I checked back here as I was about to start.
So 40:1 it is then and with a medium load.
This little genny puts out a fairly reasonable, slightly wonked but smooth sine type wave form, so I will be using a regular transformer-type 12voly battery charger.
The dedicated 12 volt output is quite "horrible" with hash and mess all over the place (based on oscilloscope wave forms I have seen from other posts) so I will be giving that the big avoid.
-- Edited by Gordo65 on Monday 17th of September 2012 11:41:18 AM
Thanks gents, So I will start it for the first time this morning with a medium load and extra oil. It is designed to use 50/1 fuel to oil so what do you think 25/1 for the first hour?
40:1 will be good for the first tank or two, certainly no more than 30:1 or you'll finish up with a gummed up carby, sticky rings and excess carbon build up.
For the first hour or so run at a medium load, then run as normal.
Do not run for any period of time without a load as it will glaze the bore.
OJ
You will also need to purchase a battery charger.
The 12V output from most generators is quite small and not really suitable for good battery charging.
