Post Info TOPIC: telford cassette toilet
Hi everyone,
Can anyone please give me suggestions on cleanning telford cassette toilets plus keeping the odour down please, what do other people do? Thanks..
Cheers, Have a great weekend everyone...
Hi Ellice - we use the blue aquachem and have never had a problem with odour. We use public toilets when available but the on-board loo is used at night and when travelling for both jobs (1s and 2s) - lasts at least a week before it is emptied - sometimes longer
Jenny and Barry
The Happy Helper
We use the home brand nappy soaker, 1 lidfull directly into the cassette when emptied, and every couple of days thereafter - no odours, and breaks it all down pretty well.
You can also use citric acid - available in the cooking section of supermarket - half the container in water, swirl it around and let it sit - gets rid of the crystallisation etc.
jules
(Ben, aged 10)
KFT
We use the nappy soaker as well and it works a treat- the thing is as there are no "chemicals" in the mix I dont feel bad about emptying it in public toilet if I really have to.
A few drops of eucalyptus oil will fix any odour problems
frank
Avagreatday.
I also use the nappy soaker, really surprised at how well it works.  No odours at all.  It is Woolworths Homebrand Nappy Treatment Plus.  I believe some brands are not as effective as others.  This one works a treat.
Chris
The Happy Helper
It seems the cheaper ones work better than the more expensive, for some reason.
jules
(Ben, aged 10)
Thanks everyone, I have tried nappy soak but did not have a lot of luck so have started citric acid to remove scale and odour, then i will try some of these others...Thanyou all again   Cheer;s   Have a wonderful week whereever you maybe.....
Oma
Agree with all the Napisan posters & Ellice after a few empties/napisan use you will find that there will be NO scale on the inside of your casette AT ALL . I dissolve 3 dessertspoon in about 500 ml hot water then into cassette. If not emptying toot by 4th day drop a spoonful in. If I remember I add the Eucalyptus but only for the pleasant gum smell! It really is a wonderful,cheap effective way to keep toot clean. We went off the chemicals 5 years ago when first read about this on CF
