Post Info TOPIC: Queery... security for bus/mobile home?
Right so Im in the final throws of sorting packing and getting it together to leave for points unknown
So question is considering my Nissan Civilian bus has 6 sliding windows either side and the drivers two sliders... how do you secure these against opportunists at camps? Ive thought of those ali mesh type things fitted along the whole of both sides would look a tad fortressy for my liking so was just wondering what else is out there?... at present its the same as it was when it was a tour bus ie: no outside fittings no flyscreening just the sliding windows... mmm I guess if I slide them all shut that should do the trick as much as any other thing... so lets put this queery down as "thoughts"? smile
Cheers!
Shane
Life is whats happening when your busy making other plans... John Lennon
BRING IT ON!!!
G'day Shane,
I don't know what to do about your bus security, but what a surprise to find you over here. Sounds like you've had enough of tourists and decided to become one yourself. Hope your sunburn has completely recovered.
graemet
Cheers!
Shane
 what about the lenth of dowel in te channel trick, that way with a shorter piece of dowel you can leave your windows ajar. Maybe even te sliding house wimdow locks could be adapted
blaze
It would be expensive, but do they make "crimsafe" screens for M'homes??? They are fantastic on the house, look good and absolutely safe from baddies, plus grandkids and dogs cant wreck them either!
Cheers,  Gerty. ... at home
We got these little doohickies from Bunnings. They screw into the track. They can keep the window slightly open for fresh air, or repositioned to keep it locked and unable to open.
We used them at home (before we got crimsafe) very successfully.
They cost about $2 or so.
Rosie
The Master
I was just about to say the same as Gerty. I have seen vans as small as Toyota Hiace with security screens in white attached, they have mesh on the inside and means you can have the window open at any time. Will eventually get some for Myrtle.
Happy Wanderer
Don't worry, Be Happy!
The "trick" is to keep your valuables out of site and out of reach from the windows and doors. What they can't see they can't grab, and they have to scramble inside to have a look for.
Those secure screens are less intimidating than the ally screens as it's just a strong black mesh which could also act as a tint/shade on the windows.
Most crooks are opportunistic, so just don't give them the opportunity to grab your phone, camera, laptop, generator, fridge, tools, etc.
Transport has no borders.
My new bus has the al screens already installed and I find them a negative.
I used to use the old dowel method and I found it enough. I did have the house hold screen fly mesh on the outside but felt comfortable that if need to I could push through it in the case of fire etc. With the security mesh it is either out through the door or die trying.
Just my thoughts but I hope later to revert back to the fly mesh and get rid of the security mesh.
CG suggestion to keep valuables out of sight is a good one. Even the GPS should be removed when leaving the RV in town etc.
Brian
