Post Info TOPIC: fuel con sumpition ford territtory 2005 awd
Fpw We have a 2006 territory, as Scott01 said below, okay cruising but uses alot when traversing hills or in a string head wind. We tow a 19ft full van and average 400km per tank. We sit on 80/85 kph Glenda
-- Edited by golivers travels on Friday 6th of April 2012 02:23:29 PM
Glenda and Gary Oliver 2010 Pajero with 2008 19 ft Jayco Sterling Our Blog: http://www.birdshootaustralia.blogspot.com http://www.birdshootuk.blogspot.com.au
fpw
hi do any know what a 2005 awd ford territory is like on fuel towing a 17ft6 poptop on petrol thanks fred
Not sure of the actual numbers but a friend who has one tells me they are reasonably good when cruising if you stay under about 90kph but when you hit the hills they really suck it in. I had a BF Falcon and that was same engine and was good cruising but thirsty as hell around town and in the hills. Not going to quote numbers from my head because they would be wrong.
http://followpeteraround.blogspot.com.au/
We have a 2011 territory ts diesal, rwd.
We get about 850-900 kms to a tank of fuel all up. Surprisingly it does well towing and we get about 10 - 12 litres/100kms- on the flat- takes more on hills etc.
Towing capacity up to about 3 tonnes.
When researching the purchase, we knew this model was planned to make economy gains on the previous petrol territories as it seems to have dome.
Rosie
Hi Rip & Rosie,
Just wondered where you got your info for this veh. I can only find reference to a 75 lt tank and urban use at 11.5 lts/100. That equates to around 600 klms with out van behind and braked towing capacity of 2300kgs. Whilst it boasts quite good power and torque figures for a 2.7lt engine
Dreamcaster & Fae
+ Gizmo
Misty RIP
Jeep Grand Cherokee Laredo V6 Diesel
http://faerietrail.blogspot.com/
The figures quoted bt the manufacturer are virtually impossible to achieve. I did a stint at Mitsibishi vehicle development and carried out those sort of tests. They are done to exacting Australian rules under totally controlled conditions and over a measured 1km after settling at the required speed. Not possible to do under normal driving conditions.
fpw
many thanks for your replys fred
2007 territory runs lpg and petrol
LPg towing 1.6ton coromal 4k per litre /25 litres per100
Petrol towing 5k per litre 20 litres per 100
Jim
I tow an 18.5 ft full van with a Territory TS AWD and regularly get 17 litres/100.  Around town 13.5 l/100.  Check the price of an equivalent? diesel of that age, check the difference in price -between diesel and petrol and work out the difference in economy.  The Territory wins on comfort, towing ability and economy in my mind.
Dreamcaster51 wrote:
Hi Rip & Rosie,
 we have had the 2011 terri gor about 8-9 months.
Rosie
This will prove I have lost the plot but here goes. ashamed
What's the sum for working it out please? confuse
REMEMBER I have lost the plot. biggrin
Our son has a Territory Diesal TS rwd and averages 900km per tank, not much different when towing as he has a jayco Eagle. Think this will be our next tow vehicle as well but will go for the awd as towing capacity slightly higher. Glenda
Agree Jim Glenda
