Post Info TOPIC: Turning Circle
Turning Circle
Does anyone know how big a turning circle needs to be?
Thinking of adding one to the end of the driveway, with the view of not having to reverse the van to get it in/out of the back yard.
We tow a 15 ft single axle van.
Rosie
If you are concreting/Asphalting the driveway a good concreter/Asphalter will know all those details Rip and Rosie.
He gave me an oval shape with diameters of 9.3 metres and 7.5 metres .............just need to be sure before I spend the money (and rip out my trees)
Rosie
R&R, if you have the space go for the 9.3. That's what I would do. You can never have enough clearance. As a driver of larger vehicles I find people that work clearance sizes out NEVER allow enough. If you have enough space when finished, you can always plant some more trees or shrubs.
Keep in mind you might be entering and exiting in the dark as well.
thanx doug
Rosie
All good advice.
Another approach off the top of my head  ...
Go to a local parking area or flat paddock on a quiet day with the van attached and a few markers like witches hats or ice cream containers.
Mark out an entrance with two markers & enter it with the van in a straight line if that's how you will approach the turning area at home.
Try out going past it a bit, maybe at least until the van rear end is level with the entrance markers, and then do a U turn back thru the entrance.
After a few tries you will work out the distance that you need go past the entrance & the smallest radius in which you can comfortably do the turn. If you are going to do a clockwise turn to the right on the final round about then maybe you will want to do a slight turn to the left before launching into your full lock clockwise turn.
Have an assistant mark out the path & take your measurements.
Could even have the assistant walk beside the van wheels with a can of talcum powder & mark out the path of the van or mark it from time to time with your witches hats or ice cream containers.
On the other hand, after a few goes on soft grass you will soon have wheel tracks marking out your turning circle.
You might need to make the final design large enough to accomodate any future maybe larger van.
Compare your result with what 'the experts' suggest.
Once the driveway is marked out prior to sealing, be sure to try it out with your tug & van.
I reckon that the final driveway should be at least as wide as a single lane at a round about and of that sort of diameter.  Find a quiet one & try it out ... modify its dimensions to suit your yard layout & favourite trees that you want to save.
Of course you could approach the task from the other end & map out the prefered path thru your garden.
Replicate this with your markers in the test area & see if it works.  MOdify as necessary.
Hope this helps
Hi Rip and Rosie.
 If you think you may upsize at some time it may well be a good idea to alow for a biger rig now.  Some tugs ( like mine ) need the M.C.G  to turn round.biggrin
All the best with it .     Landy
-- Edited by landy on Tuesday 27th of March 2012 08:11:49 PM
Ditto to that! biggrin
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 12/2025 Silverline 22.68.5
It depends on the turning circle of the tug. The van follows with a slightly tighter circle. Some tugs need a lot bigger circle than others. Check your car manual or on the net.
Patto.
Dodge Ram 3500.
NO FIXED ADDRESS.
I agree with Cupies suggestion. Would never go ahead without testing your rigs turning circle, with you at the wheel!
Cheers,  Gerty. ... at home
Thanks everyone. I have a turning circle off 11.4 metres, so back to the drawing board.
many thanks.
Rosie
My experience is that the turning circle is always more than I thought it would be.
OJ
