Post Info TOPIC: portable toilets
portable toilets
blehi read somewhere or was it here about using vinegar instead of chemicals in portable toilets.Would anyone know the ratio mix?
 I know that vinegar is good for a number of things but I doubt very much that vinegar would break down the solid waste in the toilet.
Destination: AUSTRALIA....... all over.
While on the subject, it was covered earlier. I tried to buy Coles brand Napisan. All they have is a booster, is this the right stuff.
You cant get Home brand anymore.
Mechanised Swaggies
name brand triple enzime nappy soaker 1kg about $5 in coles or woolworths is what your looking for.
steve & cheryl
70 series cruser & 16ft new age mantaray
I use what Hagar says .. and it also does for a laundry detergent that if applied in a mild solution, doesn't need a heavy rinse .. works for me!
Jon
-- Edited by jonathan on Friday 6th of January 2012 06:27:44 AM
  <<   living life  >>
I'll have a look in Parkes all they had in Budgewoi was Coles Ultra Booster, everyday soaker.
Maybe up here they will have no name brand.
I did see some place that vinigar can effect the seals.
Mechanised Swaggies
 The Coles home brand has been repackaged, it is now called Coles ULTRA booster plus and is still the same price $2.49
-- Edited by goinsoon on Friday 6th of January 2012 07:44:57 PM
-- Edited by goinsoon on Friday 6th of January 2012 07:45:28 PM
Goinsoon
Look for the active ingredient of 34% Sodium Percarbonate when looking for the WW or Coles Generic Brand Nappy Treatment/Soakers.
I know the 3kg Woolies one has been rebadged too....still the same container though
Thats good I bought some and it is working a treat.
Mechanised Swaggies
DOES anyone know what we can use to clean our portable toilet with It has a lot of scale in it, someone told us vinegar and bi carb soda, but do not know what ratio to use. can anyone help me
Sue and I got fed up with the port-a-loo scene, looking for the right additives and dump points. Also the cassette got quite heavy for us. so we saved and brought a "Incinolet" electric toilet. Ok, we have to use our generator for an hour (7.5amp) but all that's left is ash that's emptied into the garbage every week. We don't find it smells that bad, just a burning smell for a short while whilst it works and it's fitted with a catalytic converter that cuts the smell. With the paper insert you can use it for #1 and #2's. It suits us.
-- Edited by Ontos45 on Sunday 4th of January 2015 12:42:03 PM
Cheers Peter and Sue
Sounds interesting. How heavy is it in comparison to the cassette type? Is there a pic?
NeilnRuth
http://www.incinolet.com
Not for me.
Neil & Lynne
Pinjarra
Western Australia
