Post Info TOPIC: TOILETS AGAIN
RE: TOILETS AGAIN
I have my napisan in a cafe sugar shaker and I just give it a shake each day. Sometimes I flush with the valve shut and then add the napisan to dissolve over night but usually I just shake it into the pan. Works for me and easy as the shaker is always handy.
Brian
Happywanderer wrote:
smokeydk, I've already bought the BigW one. Where do I find the size and whats it called? Is it the output and is it called mA?
 Here's a pic of mine.....says size 1900..but its a 38amphour Jumpstarter
goinsoon wrote:
Went to Godfreys as I said and the stuff is Supreme as Boroma said and it it 30% percarbonate the same as Coles home brand and is 51c dearer.
Oh well I tried
 You did and thank you for doing so Brian.  The guy that I spoke to said it was 4% which is quite a lot lower than what you saw...interesting, you reckon??
Even at 30% it is lower than the Coles/Woolies nappy soaker at 34%  and probably not as readily available.  We live and learn, hey Brian.
Destination: AUSTRALIA....... all over.
Brian
 Good idea Brian but the only problem I see with that is that the product is supposed to be kept in an airtight container to prevent absorbing any moisture, which makes it less effective.
Is your shaker airtight?
