Post Info TOPIC: Hints, Tips and Great Ideas
RE: Hints, Tips and Great Ideas
Here is the photo's Gillian. I was told you can get the tap at Bunnings.
Thanks for that Doug looks like it might be the answer will go to Bunnings and check it out
Happy & Safe travelling
Gill
We always use baby powder sprinkle around wheels across doorways andaround campsite works welland cheap
YOU can also get the magnetic fly screens from waynes world shops they work allrite
The Master
Saw the magnetic flyscreens in Dollars n Cents in Childers couple of days ago. 9.99. Only about a metre wide, which I think all of them are anyway. Not side enough for my sliding door, thats why I had to make my own.
Happy Wanderer
Don't worry, Be Happy!
For those not flush with money, therefore have an oldish engine and have a condenser problem; two wires and an orange will do the job.
Yes I know the majority of these old engines are just about gone, but you never know and why I posted this.
confusedisbeliefconfusenoconfuseevileye
 I have sent you a PM Gill re the photo's attached.
Esmeralda wrote:
Doug
What size is bit that joins to the hose - I already have the hose?
Thanks, Helen
 Hi Helen,
I was having trouble with the water draining from the sink in my Avan Camper and also the sullage hose kept coming off so when I was at Lakes Entrance a month or so back someone had the set up in the post I put on further up with a tap fitting attached to a water container that just sits under the drain hole, the rest I think speaks for it self. The person gave me his approval to take the photo and let anyone else see and use the idea. We are all here to help one another.
It is 3/4 inch thread(20mm) and I got it in the irrigation section of Bunnings and the clamp in the garden hose and fittings section. I found that the thread fitted into the tap thread of the container. The reason for the 15ltr size is that the larger ones don't fit under the camper and the 15 ltr didn't have to be cut down.
I can give more detail if needed but I think it is easy to work out what I was trying to do and achieved.
Jillyb is having a similar problem so I have been talking to her about it as well but couldn't attach photos to a PM.
The person that had the idea was having trouble with water draining slowly from his on board shower and came up with this idea.
edit..typo pointed out to me
-- Edited by Dougwe on Thursday 31st of May 2012 10:50:33 AM
Doug
Thanks, Helen
Esmeralda
It aint over until the fat lady sings, and I dont feel like singing just yet!
This section would be far more usefull if each hint, tips & idears had its own heading like in the other sections. You have to read the entire section to find what is in here, A couple suggested my recent topic on filling water tanks should have been in here , but for some one  finding it at a later date is difficult.
Just an opinion.
JC.
JC.
I am noticing that some of us are having trouble re; overtightened wheel nuts and lifting off the tyre. I've had successes with (other people may not have) a couple of products on the market with names like "Tyre Weld" and similar. I've used Holts (Redex brand) and Finelec PFSSST (actual name). These things are in a large pressure can (like a big fly spray can) containing 'gas' and liquid rubber. They attach to the tyre valve in the normal manner and inflate (more or less) the tyre and seal the puncture. Now, they're only good for small (up to 5mm) punctures from a nail and such, but if the foreign object is removed and the hole put near to ground level (don't park on it) they are pretty effective for me. Once the puncture is sealed, go to a servo to adjust the tyre pressure. It's all done with the wheel still attached to the vehicle. They are supposed to be only a TEMPORARY repair, but I have driven 20K ks on one which I forgot about. Some tyre fitters don't like them (for obvious reasons) and claim that they ruin the inside of the tyre wall. I can't comment on that except to say that other tyre fitters say differently but don't like the mess from the liquid rubber inside the tyre that spills on them when they take it off to put in a permanent repair. I carry two in each vehicle and replace them one by one each year or so. About $15 depending on where you buy them and available at most auto places. For what it's worth.
Just an opinion.
JC.
 Gotta agree with you Jim.
This started out as a simple topic on the general forum and at the suggestion of a few of us Cindy made it "sticky" so I guess it's just grown.
The use of the various sections keeps the topics alive longer and easier to come back to later.
Jim
Merda tauris scientia vincit
Dougwe wrote:
Esmeralda wrote:
Doug
Thanks, Helen
 Hi Helen,
Thanks Doug - I have been thinking of something similar - my bucket keeps on A) falling over or B) overflowing - also would like to keep the yucky stuff from the bottom either off grass or out of drains - depending where I am!!  I might just head out to Bunnings in a few minutes to see how I go,
Cheers, Helen
Esmeralda
Some of these hints and tips could be in Techie's Corner. A bit of a double up.
Maybe the authors could assess where their little bit fits before posting.
Transport has no borders.
Glad to see this thread still active.
Here is another idea for you....the bowl sits on the rear of my van on the bumper and travels inside the van on a ledge under the table.
Destination: AUSTRALIA....... all over.
I've just added this little beauty to the General Forum. I like the idea of it being free standing.
http://www.ikea.com/au/en/search/?query=solar+lamp
Just an opinion.
JC.
 Have to agree with you JC. I've also added the below post to the General section.
A happy camper that was next to me a few weeks ago told me about this. It saves the sullage hose being rolled up and being difficult to get strait when in use. I thought it was a good idea anyway.
He said to cut and fix some PVC pipe the length of the CV but I don't have a lot of room under so decided to go across the back and used large cable ties to fix it to the pole carrier. I now have 4x2mts straight sections and joiners.
Thanks for the tip - I got velcro today to secure hoses etc.
enzed
Thanks for this tip - I bought leather dog collars today to strap around the awning arms when travelling. Only $4 each so a cheap safety option.
enzed
Great idea - I'm doing to sew one of these!
enzed
Welcome enzed. Glad you have already found some help on this forum.
NeilnRuth
 Thanks a lot for the welcome. Just got our first caravan and getting it ready for the first trip away, just a couple of weeks holiday to start. This forum has some great ideas and I have already actioned 3 of them. The pet collars to secure the awning poles for travel, the velcro for fastening hoses etc, and I'm making a wall 'thingamajig' to hold bits and pieces too. I don't understand why the steps would open while travelling as they seem to fit into their frame really well, but will check out the suggestion to use rubber door stops to jam the steps closed. Great forum! I'm having fun reading all the tips.
Joss
enzed
If anyone is on a Gluten Free diet, we were pleasantly surprised when we went into the super market at Cobar to see if they had any GF bread. They not only had bread but had meat pies, apple pies, donuts and all sorts of other yummy things. So we filled the freezer up!!
Corideck http://www.max4oz.com
We find that IGA's tend to have a better gluten free range than the majors. The IGA at Young in NSW had a fantastic selection.
Welcome Corideck. This is a great forum. we were in Cobar on the 17th - week before you. Glad you found the local shop was good.
NeilnRuth
light.jpgNot sure if this has been posted before. sorry if it has.
Someone put this on Facebook
Mechanised Swaggies
Ever noticed how difficult it is to get rid of the smell of prawns, crabs off your hands after eating them. After eating, wash your hands in cold tea. Smell gone. !! If you ever eat at a real Chinese Restaurant, you'll find a bowl of cold tea on the table for this purpose.....
http://www.npr.org/2011/12/28/144385288/in-philippine-slums-capturing-light-in-a-bottle
The solar light in a plastic bottle is being trialled amongst poor areas of the Philippines. Certainly a good idea for GNs....
Yep, Grumpy, hand wipes and hand sanitizer are always in our glove box. So quick and easy to use.
For our caravam annexe area, we bought a large piece of outdoor matting (adverised as being what the Army uses) that stops dirt and even sand being tracked into our caravan. I can't for the life of me remember what it's called now, but it's fantastic. When packing up to move on, it folds up neatly and we stow it in the large storage area under our bed.
-- Edited by Romy5152 on Saturday 4th of August 2012 09:04:14 PM
«First  <  1 … 11 12 13 14 15 … 19  >  Last»  | Page of 19  sorted by
