SmartBar Camp Creative
Post Info TOPIC: Will a Honda 2kva run a small aircon?
I have a honda 2.0i and want torun a small, 7000btu aircon in my motorhome.It says that it only draws 800 watts, but I amworried about the startup amps. Will the Honda run the aircon. Thanks, Bill
Not sure bill but I think as you said its the start up draw thats a problem and I thought I read somewhere where it requires a 2.5kva
blaze
Master (of Mischief)
Our Honda does start and run the aircon, it's a 2.0i so yours should do the smae, make sure you only have aircon running at startup.
Hi Bill
The answer is yes it will a motor will require near double the watts s 2 x 800w = 1600w on start up. thats a rough rule of thumb and will use 800w on normal running, Your geni will run 2000w and peak is about 2500w.
I hope this helps but do not run geni on economy.
lDave & Karan
i hooked mine up today for the first time.With a/c, it reved up at start up but after a second dropped down to a reasonably low rpm, turned on microwave at same time, reved up then it dropped to pretty much the same rpm, im quit impressed with it and yes it is a tad noisy but on the end of a reasonable power lead its almost inaudible sitting in the van. Just remember to turn off your hot water.
Steve and Maria
"Every day we make it,
 We make it the best we can!"
http://blog.travelpod.com/travel-blog/smfumei/1/tpod.html
