Post Info TOPIC: Which invertor generator to buy?
Hi all
I am looking at buying an invertor generator 2kva or above and would like peoples opinions.
I have looked at Honda and yamaha and they seem very expensive compared to the Kipor and Engel ones. I know you get what you pay for but is it worth paying so much more for the brand names?
I have also seen a Fuji micro electornics 4.4kva one on ebay for around $600 and was wondering if anyone had purchased one for these?
Thanks in advance
Brett
Live your life, not someone else's.
@brettsworldtour
We bought one of the Chinese generators - 2.5kva on Ebay for $450 with free delivery about 1 year ago & have used it regularly. It runs well. Just remember if the cheaper ones don't last as long as the Honda you can buy 4 of these for the same price. But there is no reason why they shouldn't last. We used to own a 20i Honda years ago & we can't see any difference in the performance of the one we have now.
gst
Nothing wrong with Kipor or Engel even stanley are all good I've got a honda 20i but it was the best 10 years ago.
Thanks for that, does it power ur a/c unit? I have 23' jayco motorhome
@brettsworldtour
gst
You will need at lest a 2kva my honda will start my aircon bit can not run any thing else
2.5 or 3kva best
If you haven't got a Honda or Yamaha generator then I hope your not too close to me at a campsite because most others are soo damn noisy shh.gif
Cheers Jon
hi Brett, i purchased a Kipor GS2600 a few months ago from eltham in melbourne, very happy with it, just had 5 weeks away, performed really well and is just as quiet as the honda's that were being used, in the first week for about 4 hours use a day i topped the jerry can up and found i had used 9.7 litres for the week, so happy for that, i am happy overall with, time will tell about longevity, regards, gary
We have a 2600 Kipor and its been good , have had it for 2-3 years the only thing is run it in with a heavey load from new or it will burn oil. I didnt do that and it used to stop from low oil. took it back to the dealer. he ran 2 tanks with a 1500 watt heater hooked up. It now runs well . also have a 1000watt honda. both have the same cap. I think kipor are a copy of a honda. with just a few small changes...Both quite as.....good luck there are a lot to pick from...Bob n Bev
My dear darling man ignorance is bliss. Darling the Engel is a horrid little generator that produces square wave and only has a 2 speed throttle, not an eco style throttle of the Yamaha or Honda. Darling the Engel 2000 would drive the ants out of the park they are so noisy. Darling your idea of good and good has no correlation to fact. Darling while Jacko is a surgeon vet, Jacko has repaired and rebuilt small generators for 40 years by necessity. Jacko is in possession of manuals and factory tools for Yamaha and Honda. Darling not smart to post about what you don't know.
dont leave till next year what you can do this year
next year may never come
 Agree with Jacko
Emgel make good fridges , but very poor generators .
Nothing like a sine wave which is really what many devises require to operate correcrtly or without damage
 I would also just like to repeat a WARMING for those using generators plugged into the van inlet socket to supply multiple appliances
240v from a generator can be just as deadly as your mains supply
This is a potentially dangerous practise
The general recommendation for SAFE use is to only have ONE class1 devise [one that requires a 3pin plug] CONNECTED at ANY time
Each additional devise encreases the risk for an elecrical accident if certain faults occur
Your van RCD [safety switch] if fitted, gives no protection from these faults
Your van actually becomes the FIRST appliance/devise
In the normal van you will already have additional class 1 devises [fridge , possible battery charger,air con & then maybe electric kettle , microwave etc ]
So take great care or have your existing standard RCD replaced with a URCD[universal RCD]which will give protection.
-- Edited by oldtrack123 on Thursday 15th of September 2011 11:57:47 AM
The Master
gst You've been told darlings!!
Happy Wanderer
Don't worry, Be Happy!
Ma
Consider  we listened darling.........
Aldi - 1000w generator for $349. No idea what it is like.
http://www.aldi.com.au/au/html/offers_20110922.htm
Peter,
Regarding your warning, I know nothing about electrical circuits, however I believe that with the common generators used you would have to complete the circuit between active and neutral to suffer a shock.
Not that anyone would be silly enough to ever touch a bare wire, but if 'shore' power was entirely disconnected and a Honda or Yamaha generator was plugged into the 'van 15amp outside supply socket and someone accidentally touched a bare active inside the van or standing outside on the grass what do you say would happen to him?
Also I don't see any problem operating a number of appliances off the generator provided it can carry the load and it if can't its overload trips.
Maybe you might explain a bit further please.
 Hi Johnq
 True, a fully isolated generator is quite safe from shocks to earth
And no source ,no matter what protection is fitted is safe from a line to neutral shock
Your understanding on that is correct
The problem with any isolated source is it is only stays isolated as long as a fault to earth does not develope ANYWHERE in the system
Once such a fault developes it is no longer isolated ,it has virtually an active & a neutral ,exactly the same as MAINs supply with the same attendent risks
That fault could be due an insulation failure in the wiring ,an equipment fault  or even a cut in the extension lead insulation laying on the damp ground, etc
The reason for having only one class1 connected[3pin plug] is that a 2nd fault to earth via a person is very unlikely to occur, as no other appliance which could be LIVE is connected,for the person to make contact  with.
The van of course can develope that 1st fault and evidence exists of many vans having or developing such a fault due to poor /careles workmanship
The risk is low, but accidents & deaths have occured using both portable generators & inverters in other than the recommended manner
CONNECT ONLY ONE CLASS1 DEVISE AT ANY TIME is the recommendation to minimize risk
OR have CORRECTLY fitted protection
The standard RCD fitted in the van will not function with a generator or inverter plugged into the power inlet
 It should function on mains supply
Multiple class 2 devises [2 pin plugs ]may be used with a high level of safety as these are very unlikely to develope an earth fault
What ever brand you buy, even the Chinese ones on Ebay from all reports are ok but WARNING - DO NOT EVER USE ANYTHING ELSE BUT AN INVERTER GENERATOR ON YOUR VAN.
If you do I guarantee you will cook the battery charger
Goinsoon
Peter,
Thanks so far, but I am now more confused than ever. I get it that earths can and so occur everywhere.
I use the genny in a lot of places, so does everyone else. I accept that any of the usual portable RCDs eg Arlec would be worthless for this application. The van's device is for an entirely different system and is also worthless. None of my tools have an earth plug (all double insulated).
Practically speaking, are you saying to grind off the earth of the (downstream from the genny) male 15amp plug before hooking it up to the van, or do you recommend a portable RCD (what one?) to plug into the genny and take the extension lead off that?
tks John
johnq wrote:
Peter,
tks John
Darling John, darling Peter is describing a 1:100,000,000 event.
Darling John carry on as you are and don't to anything dear to change anything. The safest thing you can do is place the generator on a rubber mat outside. Darling that is a good idea apart from a secondary insulation to earth point, also saves the generator sucking up dust with the air cooling air. Darling a portable RCD is as useless. Darling Johne preventative maintenance ensuring leads are in good order, electrical equipment and appliances are correctly maintained and kept clean following the manufacturers instructions darling you won't go far wrong.
Jacko,
Aha, the KISS Principle (keep it simple stupid), I like you already.
I do all of those things you recommend (and Messrs Honda, Suzuki et al also recommend) and wasn't really reaching for the angle grinder...
If many more have your good practical sense and humour I am sure I will enjoy this forum.
thanks
johnq wrote:
Peter,
tks John
 HI John
If they are ALL double insulated tools you have an extremely low risk of a dangerous electrical fault developing
As I said the use of multiple class2 devises[2pin plug devises ] is quite safe
 No do not interfere with the genny or the extension lead in any way
Grinding off the earth pin of the extension lead will not alter the risk
 Unfortunately  Jacko's laughing comment re risk is incorrect
Shocks & Deaths have occurred due to just the sort of problems I indicated .
They can occur ,they have occured
The odds are low but far higher than the joking comments indicate
But if you like playing russian roulette do not take any notice oif my warning
ALSO DO NOT DELIBERATELY CONNECT THE GENERATOR FRAME TO THE GENERAL MASS OF EARTH by an earth stake or any other means
A portable RCD is not functional  with a generator or inverter  no matter where it is plugged in
Neither the van or portable RCD are functional unless suitable & correctly being PERMANENTLY wired in!!
 NOTE: apparent correct operation of the RCD by triping via the test button only tests the RCD mechanism IT does not, in any way, verify correct operation of the system as a whole
This FACT is often not understood
The URCD I mentioned can replace the existing standard RCD & WILL GIVE PROTECTION against all earth faults anywhere in the system
IT must be wired in by an electrician as certain precautions must be taken in how it is fitted
Darling Jacko probably is not even aware of this product, as it relatively new on the market developed  for use with portable generators & the need for reliable protection
Yes by all means follow good practise & ensure all leads etc are in good condition  but unfortunately you cannot see what is going on inside the wall of a van where good workmanship is often nonexistant
 Faults do & have developed in van wiring due to   wiring has not being suitably protected
Metal that should have been adequately bonded to earth [frame] has not been
Screws ,staples etc have penetrated wiring livening unearthed metal
Many could still be sitting out there undetected!
The overall testing& inspection of many vans electrical systems has proven to be very poor
It is well known that much of this wiring is not done by qualified tradesmens
Shocks & near deaths have occurred
These have been personally reported on other forums
Safety is not a matter, I would make a joke of.
Sorry Darling, but I am not amused & perhaps you should do a litle more research
IT is a standard recommendation by many sources including reputable generator  makers ,workplace health & safety,  etc,  to only connect ONE CLASS 1  devise @ any time, just as it always has been with fully isolated supplies,way back from the days of "SAFETY PACKS"
THE SAME PRINCIPLES APPLY
WHO LACKS A SENSE OF HUMOUR where safety is concernedno
John If you require further info just ask ,Iwill endevour to answer any questions /doubts you may have
But KISS is not always a good idea with electricity
-- Edited by oldtrack123 on Thursday 15th of September 2011 10:22:26 PM
-- Edited by oldtrack123 on Thursday 15th of September 2011 10:32:46 PM
Darling Johnq you get those that go around promoting irrelevant information trying to make them out as facts for self importance and ego. Darling if there was an issue their would be laws preventing you doing so and warnings promoted and advertised. Darling if you read the manuals that come with generators there is no such warning. Darling why do you think there are no such warnings printed in the manuals because they are unnecessary. Darling the chances of issues with an insulated inverter or generator electrocuting a person would be in the order of probability of grains of sand on a small beach. Darling people that go around constantly promoting scare mongering rubbish are pathetic irksome tiresome tired boring individuals with nothing better to do with their time. Darling these people want to make themselves out to look knowledgeable and important. Darling those that do this think there are no other educated people within that discipline. Darling what Peter is promoting is scare mongering rubbish because the order of probability is off the planet.
Maybe we should all take OT123's advice and lock ourselves in a padded cell for the rest of our lives! Two thousand (approx) people were killed on Aust. roads last year! How many were electrocuted by one of these small generators???? If we're that paranoid we should never get in our car and head out on the road.
Some good ol'fashion common sense in making sure the extension cords are undamaged and correctly wired, likewise appliances and their cords, is all that's needed. The same precautions that apply whether connected to a generator or mains, and whether in the van/RV or at home or work.
PS: As alluded to in earlier posts, make sure that the genny's inverter output is genuine pure sine wave.  If in doubt, assume it isn't.  The top brands are pure sine wave and the output is clean and the frequency (50Hz) is stable.
-- Edited by jimricho on Friday 16th of September 2011 07:45:02 AM
Merda tauris scientia vincit
Hi JackO
Your getting a bit tiresome with your Darling,s etc
It is a fact that elecrocutions have occurred with so caslled isolated power supplies
All states workplace health & safety offices,NOW require that all such generators & inverters have permanently fitted & wired RCD WHY do you suppose THAT regulation has been brought in
 It was due to deaths & accidents
Perhap YOU DARLING ARE NOT EVEN aware of those regulations.
I personally have been involved in investigating shocks receieved while using so called fully isolated supplies
All have involved to the use of multiple class 1 devises from a single isolated supply
Yes the risk is low, but to make such ridiculous claims as you are DARLING that there is virtually no risk borders on being irresponsible ,DARLING
Why do you think it is mandatory now to have any 240v supplied vehicle fitted with a RCD ?
IT HAS BEEN A STANDARD RECOMMENDATION FOR something like 50years to only have ONE CLASS1 DEVISE connected to an isolated supply to maintain max possible safety[since the entry of SAFETY PACKS to the market]
PERHAPS YOU are not aware or understand the reasoning behind that recommendation, DARLING
My first experience of some one recieving a near fatal shock was when someone used a double adaptor on a safety pack & two clas1 tools on the same job, both those tools were within the required inspection & test period
As I said It just needs a line to earth fault to develop ANYWHERE in the system& you have an unprotected earthed neutral system. with exactly the same risk factor as a non rcd protected mains supply or cannot you understand THAT!!!, DARLING?
I will repeat what i said at the start" the risk is low but the risk exists , do you want to play russian roulette'???
The quality of workmanship in vans etc is generaly very poor  done by non qualified workers with little regard to the requirements of the AUS standards
There has been plenty of evidence of that
AGAIN perhaps you are not aware of THAT ,DARLING
 The wiring in a van is under far greater stress than fixed wiring in a house
Wiring HAS been damaged by penetration of the insulation
 Shocks & one very seroius shock that I have direct knowledge of have occured for just that reason
Others in the repair industry have reported many cases of dangerous wiring & pierced insulation
ARE you aware of ANY OF THAT ,DARLING?
AsI said perhaps you need to broaden your knowledge DARLING
Try a few other van RV sites !
AS for checking the equipment , leads etc ,yes by all means THAT should be standard practise
But can the average person be aware of insulation degrading ,of what is going on between the van walls
A possible failed earth connection ETC
How many ever get their leads, equipment , van wiring ,tested
IT is up to the individual to make their own decision but that decision should be made knowing there are risks , not based on some blaise advise that it's ALL not true
SUCH AS YOU ARE PREACHING ,DARLING
I will repeat the risk is low
TO each generator or inverter user plugging into their van power inlet socket consider the above carefully it
 IT IS YOUR DECISION IT IS NOT A MANDATORY REQUIREMENT AT THIS TIME
But it has been seen fit to make the fitting of a permanent RCD MANDATORY in all states in areas covered by workplace health & safety laws
WHY ,because the risk of failure of the fully isolation has been proven ,accidents & deaths have occurred .
IT was expected that by many that the recent revision of the relevent AUS standard AS/NZS 3001 would enforce the the same requirement on ALL generators & inverters but it was put aside @ this stage
Do not be suprised if the next revision does make it  mandatory
So again it is RECOMMENDED practise,That you only have ONE clas1 devise connected @ anytime
IT is your decision
-- Edited by oldtrack123 on Friday 16th of September 2011 08:38:05 PM
 HI JIM
All good advise
within the limits of the individuals knowledge /ability
But the Fitting of RCDs is now mandatory & has beenfor quite awhile in homes
WHY,
becauseof the potential dangers of earthed neutral systems
One line to earth fault ANYWHERE in an ISOLATED supply & we have an earthedneutral system with exactly the same potential dangers
Remember it does not have to be a full blown short all it needs is to be able to pass around 40milliamps for electrocution to occur
6kohms will pass 40 milliamps @240v
Except a van could be considered a highrisk earthedsituation similarto bathrooms ,kitchens .etc in a home
Lots of earthedmetal within easy reach
Have you seen the general standard of van wiring???
-- Edited by oldtrack123 on Friday 16th of September 2011 08:57:22 PM
