Post Info TOPIC: leaking awning
leaking awning
Hello everyone
hope you can help with our dilemma
we have a jayco expanda 2006 and are hving problems with it leaking from the top where it slides in to attach to the caravan roof
the awning itself is in good condition as is the stitching
the leaks form beads of water which drip throughout the annexxe.
has anybody had a similar problem and located a resolution
regards
peter rosemary and ollie (retreiver)
I had a similar problem and just added a little silicone to the outside area where it sits against the van and no more leaks. Not sure if I was supposed to do this, but it worked OK.
Gary
www.gdaustralia.com
i used some surfboard wax
Brian & Sue
VKS737 mobile 1078
The canvas bloke we go to said to rub a candle along the sticthing if we have a problem, so similar to surfboard wax really. smile
Gidday Peter + Rose. I had the similar problem, found the warer was leaking down Behind the rope rail, so just run a bead of clear selastic along it, 'problem fixed'
IF IT IS TO BE !! IT IS UP TO ME !!!
we had the same problem with our Jilly Jayco candle wax works a treat !!!!
Shep....
this forum is just so good!
We have a similar problem, now I know what to do, thank you!
Cheers,  Gerty. ... at home
Thanks everybody
will get up there when the rain stops and get it sorted out.
Glad to see your replies helped someone else as well.
