Post Info TOPIC: Timing belt 1HZ Toyota
80Series 1HZ Belt.JPG80Series 1HZ Belt 2.JPG80Series 1HZ Belt 3.JPGWent to replace a freinds 80series Toyota timing belt, & on close inspection of the new one noticed that the reinforcing was on the outside of 1 tooth, pays to check new!  Will be returning it & geting another one. I wonder howmany mechanics actualy check new belts befor fitting?
D.L.Bishop
How many klms did you do before replacing the belt? I have a 5l in my hilux , and you are supposed to do it every 100000 klms.Neglecting to do it can cause catastrofic consquences.Excuse the spelling.
Hi Bill Have post bone the job till a new belt arives wasnt game to fit this one. Its just turned 500,000 Kms.
D.L.Bishop
Its 500000 klms since you changed the belt?I think you will find that it should be changed every 100000 klms.Disregard if I got your message wrong.
-- Edited by bill12 on Saturday 30th of April 2011 05:19:43 PM
This will be its 5th belt Bill.
D.L.Bishop
 Bill,
Check in your owners handbook - it should tell you when to change timing belt. A dashboard light also should come on when due to replace. Whenever it's due, get it done a.s.a.p!
My 08 Prado is at every 150000
Thommo.
"There's nothing wrong with the roads, just the idiots who use them"!
2015 Turbo Prado pulling a Supreme Executive
I change mine every 100000klms, and can do this myself. it usually takes me about 4 hrs as you have to remove the radiater(and replace), and I usually replace the indler arm as well. Mine also has the light which shows when to replace the belt.Thanks for the info.
80Series 1HZ belt4.JPG80Series 1HZ belt5.JPG80Series 1HZ belt6.JPG80Series 1HZ belt7.JPG80Series 1HZ belt8.JPGIts take 2 weeks to sort the belt isue, still not real happy but there is suposed to be a 80,000k warranty. This ones a Daco belt, Very easy to change it & the Idler half hour job. Pic of how i removed the tension spring & refitted using screwdriver in last coil of spring.
-- Edited by DeBe on Thursday 19th of May 2011 05:20:41 PM
D.L.Bishop
Gates Belt.JPGGates Belt2.JPGGates Belt3.JPGThis is the old belt its a Gates & done 100,000ks.
D.L.Bishop
