Post Info TOPIC: Waeco Powersupply
RE: Waeco Powersupply
According to the following manual, there is a slider switch for setting the battery protection voltage. It provides three settings -- Low, Med, High.
http://www.waecofridges.co.uk/pdf/coolfreeze-manual.pdf
The Main PCB has a switch connector (CP5) identified as Active Battery Security (ABS SW2). After examining the circuit, it appears that there are two possible functions for this switch, and these functions are selected by jumpers J1 - J5.
In fact, contrary to the manual, SW2 on the subject board behaves as an RPM selector, not as an ABS selector. That is, the slider switch selects LOW, MEDIUM, or HIGH compressor RPM when normal mode is active (not Turbo).
The ABS setting is fixed -- the compressor's P terminal (Battery Voltage Limits) is linked to its C terminal (Common).
                   Waeco CoolFreeze CF-110
              Main PCB (028221 Rev:A) - RPM control section
              Jumpers J1, J3, J5 installed & J2, J4 not installed
                  Compressor-T (RPM select)
                    CP2-6
                      o
                |     |          |          o
                |     |          |           ) J3
   Emergency    |     |          |          o
      SW3       |     |          |          |    SW2  slider switch
       _/  CP3-1|     |          |    CP5-3 o    ABS
  |--o/  o---o--+     |          |         /
  |----------o--+     |          |        /
           CP3-2|     |          |      o/  o   o  CP5-1,2,4
                |     |          |   R3 |   |R5 | R4
               | |   | |        | |    | | | | | |    R3 = LOW (zero ohm link)
               | |   | |        | |    | | | | | |    R5 = MEDIUM
               '-'   '-'        '-'    '-' '-' '-'    R4 = HIGH (unpopulated)
             R1 |     | R7    R6 |      |___|___|
                |     |          |          o
                |     |          |           ) J1
                |     |          |          o
                |     |          |__________|
                |      \|         \|       ___
                |   Q2  |---|   Q1 |------|___|---> U3-2   Normal RPM
                |      <|   |     <|       R10
                |     |     |    |         ___
                |     |     -----)--------|___|---> U3-1   Turbo RPM
                |     |          |         R11
                  Compressor-C (Common)
                    CP2-5
    Compressor-C  o------|
      CP2-5              |
    (Common)             o
                          ) J5
                         o
    Compressor-P  o------|
      CP2-7
The new PCB is not directly compatible with the original one. The new board has jumpers J2 and J4 while the old board has jumpers J1, J3, and J5. This means that the battery voltage slider switch behaves as an RPM selector on your original PCB, but functions as an ABS switch on your new PCB (as per the manual).
attachments.allvolts.com.au/products/images_large/11998.png
   Main PCB (028221 Rev:A) - ABS control section
 Jumpers J2, J4 installed & J1, J3, J5 not installed
        CP2-5
          o
          o
           ) J2
          o
          |    SW2  slider switch
    CP5-3 o    ABS
      o/  o   o  CP5-1,2,4
   R3 |   |R5 | R4
     | | | | | |    R5 = MEDIUM
      |___|___|
          o
           ) J4
          o
          o
   Compressor-P (Battery Limit Selection)
        CP2-7
-- Edited by dorian on Saturday 6th of December 2014 09:04:21 PM
                                U3 = EM78P458AP
                                U4 = AT24C02
                                           VCC
                                           ___
                                            |_____________
                                         |  16  |  |    | | R14
                                 Q2 <----|1     |  |    | |
                                         |    20|--|    '-'
                                 Q1 <----|2     |        |
                          VCC            |    19|--------+---o CP6-4  Turbo SW
                           |             |      |              C5
      Thermistor       R8 | |            |    18|-----+-----||--> GND
          NTC             | |            |      | X1  |     ||
           |              '-'            |      |    _-_
          _V_      CP4-2   |             |      |   |___|3.58 MHz
      |--|___|---------o---+-------------|3     |     -
      |----------------o---+             |      |     |     ||
                   CP4-1   |             |    17|-----+-----||--> GND
                          ===            |      |           || C6
             Temperature  GND            |      |
             Display                     |      |
 CP6-3 o---| Enable          VCC o-------|4   15|------------o CP6-8    Power LED (bicolour)
            \|                ___        |      |    VCC
         Q4  |---------------|___|-------|6     |    ---
            <|                R9         |      |     |
           |       VCC                   |      |   +-+--+
          ===       |                    |  U3  |  .-.  .-.
          GND       +--------+---+       |      |  | |  | |
                    |        |   |       |      |  | |  | | R16
               U4   |    R18| | | | R19  |      |   |R17 |
               __   |       | | | |      |    14|---+----)---o CP6-9    Temp SW
           .-o|1 |o-'       '-' '-'      |      |        |
           |-o|  |o---> GND  |   |       |    13|--------+---o CP6-10   On/Off SW
           |-o|  |o----------+---)-------|7     |
           |-o|__|o--------------+-------|8     |
           | 24C02        CP6-1 o--------|9   12|------------> GND
           |            Display Clock    |      |
          ===                            |    11|------------o CP6-7    Power LED (bicolour)
          GND             CP6-2 o--------|10    |
                        Temperature      |  5   |
                        Display Data     '------'
                                           GND
(created by AACircuit v1.28.7 beta 02/28/13 www.tech-chat.de)
Thanks again for the input...
I'm a bit confused, there is no 'J' jumpers that I can see on the new board..(?) The 'ABS' SW2/CP5 is now incorporated on the new board. Allvolts said to slide it to the left, but was not sure if he meant my left or the other left (whether switch is at top of board or bottom, as the photo we were referring to at the time was rotated 90- switch at side)...
I've attached both boards for easy reference, but further update... I've gone full circle and back to the original issue...
I have two identical wire pairs with yellow connector blocks which I expect are to/from the thermostat CP4/NTC (resistance between these is I think ~16.6 on I think the 20K setting ). This morning I had full functioning switch buttons and LED's, but no compressor action, but when I swapped these thermostat wires it fired up immediately.... on mains/24v and runs fine, (got down to 0/10 on 4 led setting, and cuts out/in- responds to further Temp setting) but on 12V still the compressor tries to kick in but fails even with hardwired to battery/80W panel with upwards of 12.6V(a bit cloudy), which drops to just under 11V under start load- fan runs but retries startup after ~75 seconds (timed), and I have error #1
 Edited 11.08 7/12/14 Just to save any confusion;
NEW PCB (LEFT)                                 OLD PCB (RIGHT)
-- Edited by duTch on Sunday 7th of December 2014 12:09:56 PM
CP1 -> lamp
CP2 -> compressor
CP3 -> emergency switch
CP4 -> thermistor
CP5 -> ABS/RPM switch (optional)
CP6 -> control/display panel
With power disconnected from the fridge, measure the resistance between the compressor's C and P terminals for each position of the battery protection slider switch (SW1). According to Danfoss's datasheet, the position that produces a reading of zero ohms corresponds to the lowest voltage setting (9.6V cut-out, 10.9V cut-in).
                               Display PCB (005221 Rev:0)
                                    CP6-5,11
                                      VCC
              LED4     ___ R20  |     14       |     CP6-2
     Cold |---|<------|___|-----|3          1,2|-------o   Display data
          |   LED5     ___ R21  |              |
          |---|<------|___|-----|4            8|-------o   Display clock
          |                     |              |     CP6-1
          |   LED6     ___ R22  |              |
          |---|<------|___|-----|5            9|-------|   VCC (/CLR)
          |   LED7     ___ R23  |              |
          |---|<------|___|-----|6  SN74HC164  |
          |   LED8     ___ R24  |     U5       |
          |---|<------|___|-----|10            |
          |   LED9     ___ R25  |              |
          |---|<------|___|-----|11            |
          |   LED10    ___ R26  |              |
   Freeze |---|<------|___|-----|12            |
          |   LED3     ___ R12  |              |
    Turbo |---|<------|___|-----|13            |
          |                     |      7       |
          o                            |
        CP6-3                         GND
    Display enable                  CP6-12
    CP6-10  o----|         CP6-4   o----|         CP6-9   o----|
            SW2  o |               SW3  o |               SW4  o |
         On/Off  o |             Turbo  o |              Temp  o |
                GND                    GND                    GND
             Power LED1 (bicolour)
                LED      LED
    CP6-8  o---->|---+---|<----o  CP6-7
                    | | R15
                    GND
               LED2         ___               Error lamp output
   CP6-5  o---->|----oo----|___|----o  CP2-4  Compressor-D
                    CP6-6   R2
              Error
          Display PCB     Main PCB
Ok, power disconnected, checked between 'C' - 'P' resistance....same readings on each switch setting- none zero, one meter (DIGITECH) '20K' setting says 17.41, another meter (AMPROBE) on '40K' says 16.4....??...analogue meter says something completely else...!!!!
Compressor did run happily on 12V(11.5) this morning for about 10 minutes, then back to old ways....I think I might have to use two batteries in series for 24V and rearrange the charge panel to suit...and chase up one of Debe's digital thermistor
One Thermostat wire initially read 11.3? (on 20K) then nothing, but is the pair that consistently allows compressor to start, the other gave 12.02 (on 20K) then nothing and consistently will NOT allow compressor to start...
Thus far, I still have hair but maybe not for long..!!!!!
A resistance of 18K between the compressor's P and C terminals selects 12.0V cut-in and 10.8V cut-out.
The fact that this resistance does not vary as you operate the slider switch suggests that either the switch is not configured to operate as an ABS selector, or perhaps you are operating the wrong switch.
Since the new PCB has on onboard switch rather than an external one, then this is the switch that you should be using. The external switch that was connected to the old PCB via connector CP5 is no longer functional.
Definitely SW1 onboard switch, the original remote switch is by appearances identical, and nowhere to connect to..
When running, it doesn't seem to matter which position
Quote from Allvolts;
"As for the slide control, slide it to the left and leave it like this(this is the instruction from Waeco, we dont find that the position makes a difference).
>The fridge should work as before except that the the slide control will always be in the low or economy position depending upon the size in litres.'
Photos are
1) Old remote SW1
2) Reverse of New PCB, SW1 at bottom above thumb
3) Closeup of R3, R5 which are beside SW1
I'm at a loss to understand your measurements.
SW1 on your new board is configured as a battery voltage limit selector. The LOW, MED, and HIGH settings connect resistors R3, R5, and R4 between the compressor's P and C terminals. LOW is selected when the slider is closest to CP2, and HIGH is selected when the slider is nearest to CP3. In the LOW position the resistance is zero (R3 is a wire link).
The pinout of connector CP2 appears to be ...
CP2-1,2 <-- red -----> V+
CP2-3 <---- red -----> ???
CP2-4 <---- black ---> Compressor-D (error lamp output)
CP2-5 <---- white ---> Compressor-C (common)
CP2-6 <---- yellow --> Compressor-T (RPM select)
CP2-7 <---- grey ----> Compressor-P (battery voltage limits)
CP2-3 is a puzzle. I can't see where it goes, and I can't even guess at what it might be. Do you have any idea?
Some of the interconnections on the PCBs are obscured, so there could be errors in my drawings or interpretations (I've had to guess at a few).
Do the wire colours at the PCB end match the colours at the compressor end?
WAECO CF-110 circuit-Elect Thermostat.jpgWAECO CF110.1.JPGWAECO CF110.2.JPGWAECO CF110.3.JPGWAECO CF110.4.JPGWAECO.8.JPGWAECO.3.JPGIt should run on 12vdc or 24vdc. When on 12v check the voltage on the top 2 conectors ont -Danfoss Bridge C & T to run comp @ 2000RPM.JPG
If all else fails then this is how it was done with a fixed battery dropout voltage & a 2 speed compressor selection. Used the 10V reg to feed power to the electronic thermostat (this is used if its likely to be run on 24V.)
-- Edited by DeBe on Thursday 1st of May 2014 08:19:01 AM
-- Edited by DeBe on Thursday 1st of May 2014 11:42:34 AM
-- Edited by DeBe on Thursday 1st of May 2014 11:43:21 AM
D.L.Bishop
"I'm at a loss to understand your measurements. cry.gif'
How do ya reckon I feel..??
"CP2-3 is a puzzle."     Yes I agree, it goes nowhere neither on the new board, nor on the old board...
"SW1 on your new board is configured as a battery voltage limit selector. The LOW, MED, and HIGH settings connect resistors R3, R5, and R4 between the compressor's P and C terminals. LOW is selected when the slider is closest to CP2, and HIGH is selected when the slider is nearest to CP3. In the LOW position the resistance is zero (R3 is a wire link).'
I'll process that tomorrow.....I assumed when I found 'R3' that it be a Jumper you referred to earlier..?
Debe, I'll look at your pics closer tomorrow- will have time to kill......thanks
 just a note, whilst checking above stuff, still running on mains/24V, it cut out @ -6/+3 set on LED 8, so that indicates the thermostat is functioning in some kind of fashion...?
I'm hoping that all of this will be of some benefit to someone else in the future......
ISTM that the design of the 5V and 10V regulators on the main PCB is problematic. AFAICT, the input to the 7805 and 7810 can go as high as 29V, which means that even at low load currents the regulators would be dissipating significant wattage. Perhaps this could explain the failure of the 7805 on the original PCB and the consequential failure of all the ICs on both boards, assuming that is what happened.
Dorian- I noted the other day that when I left it overnight, the heat sinks were warm before I switched the unit on, which made sense when I traced the power in (it doesn't really make sense though to have the on/off downstream from the control module/control board without an on/off switch at point of entry as a standard item, rather than an 'add on' ).
Having said that I guess it's not normal to be plugged in unless in use...!
Haven't had the available time I thought this week....been suckered into 10 hour days
Debe, it seems those thermo units come in a variety of dedicated voltage, I guess a 12v one will be more versatile in conjunction with your step-down doodad for 24 V.....now I just need to find the best place to get one
The 12V one is the one I use. The step down do dad, is the 10V reg & part of the circuit board cut off a Waeco.
-- Edited by DeBe on Sunday 14th of December 2014 11:54:28 PM
D.L.Bishop
I'll get hold of 12v thermostat anyway, but as I have the goods to do so, I'll reconfigure my panel(s) and set up a 24V system and see if it runs OK off that, as it did before. .If that doesn't work, then I'll try the 12v thermostat- ¿but in that case I can't see any need for a step down doodad anyway. ..?
Hi guys, sorry to not have updated for a while, been caught up with other stuff..in fact I thought I posted this the other day.
The digital controller didn't arrive until after the NY break, so I made do with what I had. That was to rig a 24V application, which ultimately worked significantly no better than 12V, whilst away over the break.
It worked fine with plenty direct sunshine, but even though the apparent battery voltage was generally around 12V, it still did the random cutout and error light on...I have a feeling the unit is super-sensitive to battery capacity.
...however...
But the main reason today is, I need to connect the digital controller, and looking at Debe's diagram and photos, looks simple enough, but am confused by the 560 resistor, as doesn't match to the resistor codes I'm looking at...?
Is any chance of clearer details of that and the one (680 ?)on the switch ..?? I just want to make sure I get it right thanks again for your help, and don't forget I'm not a tech-head
cheers, duTch
The 560 ohm resistor is for the Fault LED. The 680 ohm resistor on the switch is to give 3000RPM on the compressor if you want it to cool down quicker, it does draw more current when running. With the switch closed bridging the resistor it gives a mutch slower 2000 RPM  (economy) draws less current when running.
D.L.Bishop
Debe and habana have successfully removed the PSU but for the life of me it has me beat.
Sorry new to this forum and found it trying to solve a Waeco CF60 error light condition mucking around with temperature of the fridge. Even though the thread is old I hoped these guys still look in.
I bought the 9 amp polyfuse but struggling to pull the PSU unit free. The condenser pipes are in the way. Even lowering the compressor tray and bending the bottom tube, there is no way of pulling the unit out. What also stops it coming are the leads and suppression doughnut on top of the plastic housing getting in the way.
If those who have been successful doing this task, I'd love to hear some clues I might be  missing.
-- Edited by phild01 on Wednesday 26th of April 2017 03:13:45 PM
-- Edited by phild01 on Wednesday 26th of April 2017 06:52:58 PM
The only reason I answer is I get an email notification when theres a post here. Have marked your pic on where I have bent parts to get it out, it is not an easy exersize.CF60.JPG
D.L.Bishop
Thank-you muchly DeBe, was the critical encouragement I needed. Just went back to it, un-taped the wiring, clipped the wire tie at the top and withdrew the thing. I really should have just done the suggested bypass with an external temp control. It's my BIL's fridge and he needs it soon.
Hmm, I need to drill the pins that hold the board in, not to mention the glue. Must be devised as an anti-tamper warranty thing!
-- Edited by phild01 on Wednesday 26th of April 2017 09:51:17 PM
-- Edited by phild01 on Thursday 27th of April 2017 05:40:29 PM
Got it all back together and working like new.  I got a response from Domeetic-Waeco claiming that pre 2006 CF60 would not have a problem and if so it is because of low voltage/power supply cabling.  They are in complete denial that the 2006-on models were simply upgraded because of this fault, and claim the pre 2006 models had no fault.  Yep and pigs can fly.
Anyway BIL happy and thanks to you guys, I managed to identify and fix what Waeco won't admit to, to me anyway.
-- Edited by phild01 on Monday 1st of May 2017 10:38:32 PM
-- Edited by phild01 on Monday 1st of May 2017 10:39:25 PM
-- Edited by phild01 on Monday 1st of May 2017 10:40:21 PM
Good to see you was able to fix it.
D.L.Bishop
Hi, I'm having problems with my CF40 on 240 volt. I have accessed the power supply board (exact same as yours at the start of this thread).
I can't see anything visually wrong.
When I plug the fridge in, it rapidly flickers on and off, and the relay can be heard flicking. When I then unplug it, the relay clicking gets slower, to a stop.
I have checked the output voltage of the board, it goes up and down from 8-12v.
What could the most likely cause of this be? Not wanting to fork out nearly $200 for a new power board.
Thanks.
Posibly C4 100uf 35V electrolytic capacitor has dried out.
D.L.Bishop
Thanks for the reply DeBe.
I have replaced the C4 capacitor, fridge is doing the same thing.
When it's plugged into mains, but switched off, it makes a high pitch pulsing sound and the relay stays engaged.
When I then turn it on, it jumps up and down, relay goes on/off.
My electrical knowledge is pretty basic, but it would seam like a capacitor problem. Are there any other you recommend I try?
It does work fine on 12/24volts.
Thankyou for your input mate!
Its looking more like a fault in the electronics of the supply, not capacitors. Unless you are fairly competent in repairing SMPS, it will be easier & cheaper to remove the in built 240V unit & just buy & use an external 240V AC to 13.8V DC @ 12Amp. That's how I run one of my fridges, there are 240V to 13.8Vdc @ 12 Amp power supplys available on E bay for $70 free freight here in Australia.
D.L.Bishop
Hi Guys, I had a couple of emails indicating recent activity. I've realised I haven't been back to report/update my dysfunctional 12V operation.
I did all that was suggested with mixed results from memory (digital controller plus/plus) and profusely thank everyone for their help and tolerance, mainly dorian and Debe (without re-reading the whole thing).
I finally bit the bullet and invested in a 120AH AGM Deep Cycle battery, reinstalled/replaced the factory control boards and it now works fine for the once -a-year use it has.
I think it's taken time to come back because I needed to make sure it was all well first, had work interfering and hands and mouth full of humble pie....and had memory lapses
The bottom line is letting you all know the outcome, and for any one else with a similar issue , even though the battery I was trying to use showed enough Volts, it just wasn't up to the task.
cheers and thanks again
I am using quick reply so not sure where this will end up.
My waeco is about 10 years old and I had to fit a new thermostat about 5 years ago.
It was running as a beer fridge for the last 8 weeks on 240v when it froze some cans. After turning up the thermostat it let the contents get warm. The temp readout at that stage was reading ok
Thinking it needed a new thermostat I pulled the covers off and then discovered that the read out has "er1" on it. No flashing lights and the compressor will not run except with the emergency switch.
I have spent hours on the net searching for a workshop / service manual no luck.
My bottom board is a ver 0 and appears to be unobtainable.
«First  <  1 2 3 4  >  Last»  | Page of 4  sorted by
