Post Info TOPIC: Cleaning Watertanks
Cleaning Watertanks
Has anyone got any ideas about cleaning out their water tanks and what do they use to cl  Keithean it with. There was a thing called Milton which was used to sterilize babies bottles and I wondered if that was still available...Any help greatly apprecciated
The Master
There was a thread on here not that long ago on exactly that. I use bicarb soda in mine. There was lots of ideas on that thread.
Happy Wanderer
Don't worry, Be Happy!
The Master
Water gone Bad was one heading. Type it into the search at top in the blue line. There are a couple of hints in there. There is another one but can't find it at the moment.
Just found another one Water tank Maintenance.
-- Edited by Happywanderer on Friday 15th of April 2011 02:44:35 PM
Happy Wanderer
Try a product called "CLR" (it can be purchased from Bunnings Hardware stores), leave it mixed with water for about 48hours then drain and fill with fresh water and add bicarb soda as HW suggested leave for another 48hours then rinse thoroughly and refill with fresh water.
Regards Jim
Regards Jim
see if this werx
So KeSue if you went back to Gerty's orig post , early Dec 10 , you will get this .
Sorry Gert fo cutting ya head offdisbelief
Richoevileye
Reply Quote
Have just realised our van wont be used for 3 months, and wonder if we should empty the water tank, or put something in to stop it going "off"?
I dont think, if we try to empty it, that all the water will drain out, leaving just a bit in the bottom to become yucky. bleh
What do others do to keep their water tanks clean?
Cheers,  Gert.  ( Canberra)
ozjohn
1258900?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=PAyOXrCei6rTPd6F80MWl6rCCxY%3D&1271042543
Date: 02:29 PM Dec 4, 2010
Reply Quote
I leave our tank at least half full when in storage.
The day before we depart I then drain, refill, and drain again.
I then refill once more ready for our trip..
That way it gets a goog flush and if you use a good quality 'Food Grade" hose you shouldn't experience any foul tasting water.
Cheers, ozjohn.
Ford Territory - Roma Elegance 17'6" Pop Top on order.
Onedodger
1229492?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=ctV5xV0ukGiXlu5wAeD9J%2FljrMU%3D&1266117742
Date: 02:35 PM Dec 4, 2010
Reply Quote
confuse   I keep the tanks full when the van is idle at home then mt and flush & refill a few days  before takeoff.
We have never had algae in 30yrs vanning.
Cheers Dodg.
Ron and Shirley
1210617?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=ooz3h%2FPlNqe3PO%2Bl8dPM%2BlSpmSY%3D&1262852029
Date: 03:44 PM Dec 4, 2010
Reply Quote
We make sure the water tanks are full when we park at home. Then just a week or so before the next trip we empty the tanks, give a flush of the tanks and all lines, then refill the tanks.
If the last fill of the water tanks on the road was with water that was not to our liking/taste but OK for washing etc, then at home we would empty, flush, and then refill.
We use food grade hose for filling the tanks.
Ron & Shirley
www.ronshirl.net
jimricho
1112508?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=PyUr6IFhziMIuI%2BlkKYNJvSc1zM%3D&1269808161
Status: Online
Date: 06:27 PM Dec 4, 2010
Reply Quote
Slightly off the topic of water tanks but nonetheless on food grade hoses, I have found that my food grade hoses (a couple of different types) do impart a taste to the water when hooked up to a water tap and the water is allowed to sit in the hose for while. I have eliminated the tap water itself as being the cause.
Is this normal?
I have a normal plastic (food grade) hose plus a roll-up flat one.
Gerty Dancer
1295350?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=HO4Htmyc4NquCRiH0%2BhZgniThEw%3D&1287286959
Date: 08:40 PM Dec 4, 2010
Reply Quote
Yes I think that taste from the hose itself might be common, I blamed it on the hot sunshine warming the hose while it had water in it. Just flush through and its fine.
ozjohn
Date: 09:13 AM Dec 5, 2010
Reply Quote
Ditto.
ozjohn
Two Strays
Date: 01:00 PM Dec 6, 2010
Reply Quote
Hi all
When I'm not using the van for a while I fill the tanks.   This limits the airspace in the tank, thus reducing the likelyhood of bugs and bacteria from developing in the tank.
When we are setting of again I drain the tanks and refill them.
Don't use garden hoses to fill your tanks.   They taint the water, use a food safe hose.   Another source of contamination is the filler hose.   Many caravans have clear inlet hoses.   These are exposed to the light and subsequently allow slime to develop in the hose.   Replace them with food safe black hose.
At least once a year I flush the tanks out with "TankKleen".    Just follow the instructions on the container.
I also pour in two table spoons of vanilla extract (NOT Essence) in the tank as well.   It seens to keep the water sweet.
You must try and keep well when travelling.   Clean water is the first step.
Date: 12:29 PM Dec 12, 2010
Reply Quote
If you want to give the tank a good flush out you need to half fill and empty it several times. Alternately you remove the drain plug on the way home and let the last 5 - 8 litres of water to be forced out buy centrifugal on corners and bends.
I use the latter method after our big trip each year. I then immediately fill the tank whilst the van is being unloaded. With having the tank full of water and a minuscule amount of air, we have not had any bad taste in the water.
Nissan Navara D40 diesel auto, Spaceland pop-top
Don't worry about old age--it doesn't last long.
Smokeydk
983989?AWSAccessKeyId=1XXJBWHKN0QBQS6TGPG2&Expires=1303948800&Signature=Y8zwuudORTg5l5rqxdmQqlY96VY%3D&1279581193
Date: 09:24 AM Dec 13, 2010
Reply Quote
PeterD and Ozjohn.....you both might be able to help me regarding water tank.....
My caravan..water.is terrible.....I flushed the tank when we got it new.....several times....went away 2 days later...water in sink was yellow..........got home emptied tank again.......flushed it 4 more times....water was fresh...went away again.next day......water was tainted...plastic taste....all hose from tank on this new van are black....
I've heard Bi-carb suppose to be good.....how the hell you get in tank...I have trouble getting hose in it??
Dave
Old Noarlunga SA
Getting away is fun, staying home can be glum.
NP Pajero and a Goldstream Mini
blaze
Date: 09:44 AM Dec 13, 2010
Reply Quote
mix the bicarb in a watering can and tip in
blaze
lencerpetro
Date: 05:24 PM Mar 26, 2011
Reply Quote
We ensure that water tanks are full when you park at home. Then just a week before the next trip to empty the tanks, give a color of the tanks and all lines, then refill the tank. Do not use garden hoses to fill their tanks. Staining the water, use a hose for safe food. Another source of contamination is the fill hose. Many caravans have clear hoses input.
Rainwater tanks
Does not say a lot to what you want to Know , but may give some ideas .
Richo.
-- Edited by Zoomtopz on Saturday 16th of April 2011 06:37:52 AM
Richo
I use my garden hose to fill my van tank at home, never had a problem. Of course I let it run for a couple minutes to give it a good flush before filling.
To keep the tank 'sweet' I put a couple capfuls of household bleach (chlorine) in and top up the tank when in storage. Before going on a trip I drain & refil, again putting in a couple capfuls of the bleach.
If we are in a caravan park for a few days then I use the foodsafe hose to connect from the standpipe to the van and also to top up the tank if necessary as water will be sitting in the hose for a time..
To the people saying they still get tainted water from their blue (foodsafe) hose....if you bought cheap hose from Bunnings or somewhere similar then that is the problem. Get good quality hose from a van shop.
Cheers Neil
-- Edited by Delta18 on Saturday 16th of April 2011 10:31:51 AM
Neil & Lynne
Pinjarra
Western Australia
Hi.
Milton is still available in two forms. Tablet or solution. Bought a one litre this morning at the local priceline pharmacy[could only find tablets at s/market] and have dosed my pre-rinsed tank. Off for a ride to get it going, then another rinse and re-fill, ready to take off imediately after easter. About %##* time.
Chris
