Post Info TOPIC: EvaKool Project
EvaKool Project
Fridge job.JPGFridge job 7.JPGFridge job 9.JPGFridge job 14.JPGFridge job 19.JPGFridge job 20.JPGFridge job 24.JPGFridge job 25.JPGFridge job 26.JPGFridge job 27.JPGHad a Waeco CDF-40 that the foam insulation had absorbed moisture & was afecting the insulation propertys. So i cut it up & found the insulation is only 20/25mm thick. Since i had a good EvaKool fibreglass Esky & its insulation is 40mm thick. Decided to convert the esky to a Fridge/Freezer using the Waeco parts. It apears to work quite well.
D.L.Bishop
Fridge job 28.JPGHave decided after some thaught to enclose the compessor, & fit an ajustable barrier in side so it can be used as a freezer oneside & fridge on the other.
D.L.Bishop
looks very much like my evercool fridgemate
blaze
EVAKOOL THERM.1.JPGEVAKOOL THERM.2.JPGWhere I fitted the thermistor to the evaporator.
D.L.Bishop
Inside looks a hell of a lot like my Evakool ED70 fridge /freezer.
Cheers  Keith
Nuthin is ever the same once I have owned it ......
