Post Info TOPIC: Pressure Hatch
Pressure Hatch
Most new vans have a pressure hatch presumably to keep out the dust while travelling.As our van is a pre pressure hatch,if I put the front vent of the 4 season hatch onto rain would this work the same?confuse
http://www.nomadsnotes.com/AP.aspx?ID=551&EID=10594211
...and lovin' it....
seems to work from what I've heard
I wouldn't do it as I've found the four-season hatch to be fairly fragile. Maybe you could just do the back flap, but definitely not the front one. It's very flimsy if mine are anything to go by.
I don't use the pressure hatch at all. I did find mine leaked this last trip, so I had to put a tarp on the bed with a towel to soak up the water.
I don't know where the leak is exactly, as it only happens when I'm travelling, not when I'm parked.
What we do with these caravans I think is not the intention of the builders and dealers. They look really pretty in the yard, but put them on the road and all the pop rivets pop loose, and the staples fall out.
Transport has no borders.
Chriss, the difference between water leaking when travelling vers when parked is the amount of wind pressure on the seals /windows etc,same with leaks in cars you can hose the all day & not leak but drive in some rain & you have a leak.
I have chassed these leaks many times over the years at work & can be very hard to find.
JC.
Using the front flap on the 4 seasons hatch will work for awhile, but  wouldn't attempt it if you value the flap/hatch as they have a habit of flying off when supjetced to high velocity winds.
Cheers, ozjohn.
I concur with others here the four season vent is not made to take the strees of the wind past it while traveling (even if you go slow).thumbsdown.gif
You can install a Scupper Vent yourself and this I have done just find an apropriate section and ensure when you start to cut a hole do not go through a cross frame.
I then also made a little velcro fly mess on inside to stop fourign objects if they occur geting in.
Would also recommend the 240mm x 150mm scupper vent and the internal frame. They were relativley easy to install but stress make sure you avoid a frame strut.
I have had a spring break once so recommend purchace a spare spring and carry as if away not as easy to get hold of if happens.
-- Edited by Alan8888 on Thursday 24th of March 2011 10:36:55 AM
Alan & Sharron
Credo Homestead & Campground
VKE237 HF Radio Club Inc - 6451
 I think this would have the opposite effect to what is required, it would tend to create a low pressure inside sucking dust & water in.
I too think the 4 season is too fragile to leave open while travelling.
Neil & Lynne
Pinjarra
Western Australia
Thanks everyone for the advice.The scupper vent might be the way to go.smile
