SmartBar
Post Info TOPIC: motorhome toilet on house system?
wondering if its possible  to have some set up
so when home and we have visiters, and they stay in the van if spare room full,
can we have a set up so the toiled is used with the house system, if you can gather my thinking?
milo's site
Why can't they just use the House Toilet Milo?
just an idea
milo's site
The work to plumb it into the house system would be too great for the benefit received. Just let them use it as it is and teach them how to empty it.
Tell 'em "You use it, you empty it"
Also tell them they can put anything they like in the toilet provided they've eaten it first.
Merda tauris scientia vincit
noconfusehmm
by the way, we havent used our toilet in the van yet, saving it for when we free camp i guess, how hard are to empty?
milo's site
Very easy to empty Milo.
Find the nearest "dump point", open the lid and pour.
Then flush out with fresh water, add the required amount of the chemical of choice, screw lid on TIGHT, and return to orifice from whence it came.
I don't put any solids in mine - not even paper, but paper is acceptable, but that's up to you, especially if you're free camping. Other solids may have to be permitted, as Jim said.
I guess, if you get caught short you can grab the shovel and take the rolls for a run.
There is a button on the top on the opposite end of the tank which if pressed very firmly, will release the gases to allow the contents flow out quicker, and more cleanly, sort of.
It's all part of the lifestyle. Have fun.
Transport has no borders.
Just remember that the environmentally friendly chemicals do not work properly with just urine in the holding tank. Urine is fairly sterile so there is nothing for these type of chemicals to work on. If you are unwilling to crap in the system you have two alternatives:
1. Add something like meat or yoghurt to the holding tank to react with the chemical.
2. Use one of the unfriendly masking chemicals.
If you have both urine and faeces in the tank together with the correct dose of chemical will result in less smell when you are emptying your tank than just urine alone.
.......and, judging by the responses on another famous caravanners' forum, the correct dose is:
- one capful of generic brand nappy soaker pre-dissolved in a litre of warm water put into the lower tank and just plain water in the flush.
Add yoghurt to taste.    biggrin
Try this for a bit of a read.
