Post Info TOPIC: Glueing styrofoam to inside of painted metal van wall....rust?
Can I line my campervan with styrofoam to insulate by glueing to walls and roof and then cover with fabric? I'm concerned about possible condensation and rust between the two....what do you think?....thanks
Just answered my own question ......will get a 5 metre roll of magnetic vinyl and glue strips to back of foam panels .....That way I can air it out by removing the panels regularly.  The vinyl is about $180 for 5 ms...found it on th net!....love being self sufficient!...its great fun nutting out these challenges!
-- Edited by Denise on Tuesday 16th of February 2010 03:09:06 PM
If you want better insulation, use high density urethane foam instead of styrofoam.
The insulation quality will be about twice as good for the same thickness.
Thanks for that,   Is that sheet or spray on?  Will I have a problem with rust if its sprayed on?  Dont know anything about it. Is it expensive? DIY?
I bought it in Adelaide in 25mm thick sheets. I used it for fridge and freezer insulation. Not too expensive. You can use most glues too, not like styrofoam that disolves in most.
Thanks for that...my biggest concern is whether condensation (from inside/outside temperature differentials)  between the foam and metal  will rust the van walls on the inside. ....thats why I thought removable panels might be wise. What do you think. Have you ever checked under yours? Thanks again....:)
We don't have any metal in the camper walls Denise (we are fibre glass sandwich panel), so it is not an issue for us.
If the metal is cold on the outside amd is allowed to get warm and moist on the inside, then condensation is a possibility, but where it is properly insulated and sealed it should be OK.
We do get condensation around the aluminium pop-top frame sometimes because of this.
Thanks, I think I'll make them  covered removeable sheets do you remember roughly how much a sheet?...   :)
Hi....I thought ( seonau thinking? a bit of a wobbly start ) when it comes to insulating there must be an air gap between the two surfaces so heat or cold is not transferred via conduction. ?? Air is a very poor conductor of heat.
The idea of putting up panels like you plan is a really good original idea i think but it might be better, if the air gap theory is correct, to make some sort frame between the outer and inner surfaces to create that gap.
I just read a second ago you have some silicon.... while silicon is not a good adhesive generally, the one you mentioned you have is. The perfect product to use to stick a urethane foam frame work up on metal and then use magnetic tape on those.
As always my opinions are just that and since i know there are people here with a lot of knowledge, help me folks.
SEONAU...AKA..."PIRATE PETE"
No matter how hard it is raining, two pirates may never share an umbrella.
4 sheets 2440 x 1220 x 25mm purchased on 15/7/2004 from Huntsman at a cost of $179.12.
There won't be condensation on the inside of the roof if the warm air is excluded and the moisture does not get there. You don't get condensation on the fridge walls for the same reason.
Urethane is a poor conductor of heat and these materials are mostly air, so an additional air gap is not required. Yes, air is a good insulator, but it must be sealed up in 'pockets' to stop circulating currents spreading the heat around. Urethane foam is the material used in fridges and freezers. It is a light brown colour.
