Post Info TOPIC: Towing in 5th gear
Towing in 5th gear
Thought I'd continue the discussion following on from the "dual cab utes" post as a new thread. Amazing how the topic sometimes drifts on this forum....(guilty as charged Your Honour).......
Is it possible to have a "one size fits all" policy on whether to tow in 5th gear as it would seem to me there are many variables such as......
The tow vehicle.....make, model, sedan, wagon, small 4x4, large 4x4, etc...
Manual or Auto,
Diesel, Petrol, Autogas
Large van, small van,
etc, etc.
-- Edited by jimricho on Tuesday 15th of December 2009 05:51:16 AM
Merda tauris scientia vincit
Good question there Jim
Going arround a bit of Auss. i often was tempted to hit the cruise in my Holden [auto], some say never use cruise when towing [15ft van], others say its ok, been tempted when tail wind  gets me rolling.
 What do u seasoned travelers think?
demon dave
I have always driven by rev. counter or engine sound.If the engine starts to Lug then you know it is time to change down a gear or two.Autos change for you when the torque changes.Diesel engines tend to hold on longer than petrol engines.I guess it is a question of look,listen,feel.Experience is the best teacher of gear changing strategies.Cheers.Ibbo.
"Wings Over The Navy"
Cruise control and towing is not a good idea safety wise.Cheers.Ibbo.
Ma
You and us too Marty.  Must be something to do with being "up there" perhaps....laughing.gif
Guru & Ma
Ulladulla NSW
Happy day, safe travelling
Ford Ranger towing 21ft Jurgen shower and toilet which was large enough to fit in a few extras (fridge, bed, stove...)
Nothing to do with being up there Rob. It's just when you and Ibbo started driving.......Tachos weren't invented. LOL
Daisy and Disco Duck
Adelaide South Australia
Gotta Think Outside the Square!
Now that food has replaced sex in my life, I can't even get into my own pants.
If at First You Don't Succeed.......Redefine Success !!
http://www.exploroz.com/Forum/Topic/54653/Towing_in_Fifth_Gear.aspx
Quite an interesting site about towing in fifth
Ma
Neither were gears Ducky, just peddle power, or was that foot power??
Guru & Ma
Ulladulla NSW
 Please explain? I'd suggest that this depends on where you are towing, certainly if you are in traffic it's not a good idea but on the "open" road I can't see any issues unless Cobber you are concerned that everyone drives like my MIL, stopping at green lights, thumb up bumb; brain in neutral.....
ok I'll have a go at this at the risk of getting in to more strife, towing in fifth gear is not a "one answer fits all", your vehicle is an individual, get to know it
overdrive or final gear is fine in both auto or manual when the going is EASY, I.E. flat level ground, tail wind, very little or no effort required by the vehicle but the second you see the speed dropping or she's "pulling" a bit get it out of that gear quick smart, do not "strain" your gearbox or it will fail
towing is about knowing your vehicle, listening to the engine, knowing when it's working and when it's running nice and easy
overdrive and the cruise control on say the nullabor is fine or any highway that is open with a good line of sight, plenty of room to "react" if trouble arises, no reason why it cant be used, just a dab on the brake and its off
if your vehicle is automatic with an "overdrive" and not a true "fifth gear" then I would not tow with this gear, it can be used only in very easy going circumstances, get this info from your dealer, there is a huge difference between overdrive and a fifth or "final" gear
listen to your engine, watch your revs these are far more important than the actual ground speed indicated by your speedo
keep the rev range as close as possible to your "power band", get to know where this is
most bands are between 2,000 and 2,800 rpm, not all are the same, diesels can "lug" a little better than petrols but try to keep it as described
I have now left myself open to all sorts but I use this description after decades of driving semi's, tippers and heavy plant as well as years experience in auto and heavy mechanics
driving within the power range of the vehicle, and this is not necesarily the peak power range, will give you far better economy as well
another good idea that has been lost over the years is the instalation of a vaccuum guage, this little instrument can tell you, by way of manifold pressure, or lack of it, just how your engine is performing "pulling" wise
and your driving technique can be adjusted accordingly
just on the "tacho's werent invented yet" statement by ducky, when I first started "heavy haulage" my first semi was a "b" model Mack quadbox gooseneck with a lowboy 20 wheel heavy haulage trailer
very few insruments in there, but right dead smack centre of the dash was a tachometer, it was between 8" and 10" round, that was the main instrument,
I really cant remember there being a speedo in there but there probably was, it just wasnt important, I never looked at it, revs, not speed is the important factor when towing
If you have an automatic just put it into drive and the the car do the thinking, but as Dave says you still have to keep  the rpm in the "Torque" range. If the torque range is say 2400 -2800 rpm and this equates to 98 - 105 km/h then that the best speed to drive at when towing because towing is done by the engine torque not the power, the power gives you acceleration.  So in those curcumstances if you drove at say 80 to save fule you really are not because because you are not allowing the engine to reach it's "sweet torque range".
The gear you are in would be irrelevant as long as the engine is running in the right rev range...
Basil i think you are spot on
My tug doesn't have a tacho, although I have thought about adding one.
However, I have a good "ear" for revs in the diesel, and drive by revs and power available.
I still wouldn't tow in 5th, overdrive in this case, because of the speed I tow at. But that's just for my cruiser.
Every vehicle behaves differently, and turbo changes the power/rev ratio.
Transport has no borders.
You are not in strife Dave.Your reply was a fair and just answer to a fair and just question.As I say you live and learn.Cheers.Ibbo.
Whats wrong with using cruise control while towing ? ,we have just done around 20,000 Km
towing 17ft van with auto falcon with no problems and good economy,
Set to 100km/hr and foget it.
It drops to around 80k on steeper hills but genraly just looks after itself.
just hit the brake to kick it out for roadworks etc.
I do notice most of the diesels seem to die on the steeper hills where as the petrol keeps hauling all the way to the tup.
http://mikeandcushla.blogspot.com/
I can't work the out Whoppa. I put the camper van on the Disco......put it in drive and use cruise control everywhere....even in the city!! No problems.
Maybe you can't do that with the Japanese stuff?? Ahh well......maybe they catch up??
Ma
Sorry Whoppa but I must disagree there on the diesel angle.  We have a Ford Ranger, 3ltr Turbo Diesel towing 18.5 ft van and it has just eaten up the hills.  Eg. Clyde Mountain on Kings Highway, Cunningham's Gap on the New England and others I can't remember........Alkaseltzer diesease don't ya know......laughing.gif
Guru & Ma
Ulladulla NSW
It all comes down to power and torque.
Falcon is 195 Kw and 391Nm torque 4litre
Ranger is 115 Kw and 380Nm torque. 3 litre turbo
but hey if Diesel works for most I won,t argue
we leave our 6 speed falon on auto. and drive @1500 to 2000 revs which is around 90 to 100 ks. with our 505 coromal. (on climbs we can get back to 80ks or lower)this is the same revs as when we drive without the van @110k.
was once told by before tachos became the norm that if you travel @ 20ks under your normal driving speed you shouldn't have any great transmission problems.
 brian & kerry
505 coromal & duel fuel 2007 falcon
brian & kerry
2010 avan
ovation
Ma
Thanks for the heads up on the stats Whoppa.  I wouldn't know a Kw from a Nm at the best of times.  and like you say if it works for us, bloody good show.
Ma
Guru & Ma
Ulladulla NSW
A good range of responses here.....what this forum's all about.
It was after seeing some suggestion about not towing in 5th gear in the previous post (d c utes) I decided to start this topic to get some more input as I do tow in 5th.
I think from the responses I'm on the right track with my Pajero (NP 2003) manual diesel towing a small "wind up"........
The engine has a "sweet spot" at around 2000 rpm which equates to around 90 kph (GPS checked) in 5th, a good towing speed for the rig.
I don't let the engine "struggle" (towing or not)....I change back
ok to use cruise control but with discretion depending on traffic and road conditions. In my case I find using cruise control significantly reduces driver fatigue on a long trip, a safety factor in itself.
JRH
I do not have cruise control on my 1993 Falcon so this is pure speculation.
It is my understanding that cruise control will simply open the throttle further to pump more fuel to maintain the set speed if the vehicle begins to slow down, so when towing a caravan with cruise control engaged and you suddenly hit a head wind you will simply use a lot more fuel and run the risk of labouring the motor and putting undue strain on the gearbox.
As I say this is just speculation on my part as I have not had any experience using CC.
If I don't get there today, I'll get there tomorrow or the day after.
John & Irona..........Rockingham Western Australia
Cruise control is great........set and forget.
Then climb back into the van and make a coffee. You guys really know how to travel I'll say that!!
JRH
Why stop at coffee, why not a couple of scotches????????  After all Cruise control is in control is it not?biggrinbiggrinbiggrin
Having had the diesel Patrol for a year now and done a couple of trips I've found that the auto is best with the O/D disengaged. A bit like with Falcons, towing in third gear with the auto. As for cruise control, it works fine with the diesel.
Terro
Rosemary and Terry08 Patrol, Galaxy Odyssey Pop top                       He who laughs last is late getting the joke!!
Tow in the highest gear that still allows reasonable accelleration to be achieved by opening the throttle some more.
If the accelleration is poor, drop back a gear because the engine will not be operating at efficient RPM.
Cruse control will use more fuel than sensible 'manual' control of speed.
In the Falcon it does not seem to work that way as when you get to a decent hill on cruise it will slow to around 80 K,s ,however if you wish you can still  hit the fast pedal which will overide the cruise control and allow you to speed back up to 100k,s which can be handy if you are on a fourlane highway and really need to pass something, this does have a downside thou as fuel consumption goes off the scale and yes I guess it starts to add load to transmission etc.
I am not sure how the cruise control works but belive it uses engine vacuum and trottle position sensors plus some sort of computer logic to try and maintain a balance or speed and fuel consumption and load on mechanicals.
Mostly I leave the car to make up its own mind  if slows on a hill as Iam in no hurry anyway and just want to get there in one piece.
JRH
Thanks for that info Whoppa, it clears up a few misconceptions.
Hey guys, I reckon if your motor is doing 90 - 100 kmh @ 1500 - 2000rpm with the van on and 110 kmh at the same revs without then I would say you have too much slippage in the trans, either in the torque converter or maybe clutches are slipping.  Smell the oil on the trans dipstick.  Does it smell burnt?
Neil & Lynne
Pinjarra
Western Australia
