Post Info TOPIC: Tyres for the Patrol
We need to get new tyres for the Patrol. Any suggestions / recommendations ?
An all weather all rounder would be good.
Cheers, Freddo
confuse
Goodrich All Terrains seem to do it all.
The tread is big for sand and mud - worked for me.
The walls are thicker to protect against staking as much as possible.
I'm very happy with the ride, and I am not aware of any road noise.
I've had all-terrains on the cruiser for more than 30,000kms in 4 years and they barely show it.
Worth every dollar.
Transport has no borders.
Depends on what you use them for.
Do you go off road or stay on the black stuff??
Daisy and Disco Duck
Adelaide South Australia
Gotta Think Outside the Square!
Now that food has replaced sex in my life, I can't even get into my own pants.
If at First You Don't Succeed.......Redefine Success !!
Mostly the black stuff and a little of the red stuff.hmm
I use the same tyres as Granny does. The BF Goodrich A/T's
It is a very good wearing tyre with lots of grip as an all rounder. Most people that use them get at least 80,000 k's out of them and the sidewalls are one ply thicker than the normal all rounders as they are classed a light truck tyre
I have them on a Discovery 2 and do get a fair bit of road noise from them. It is the only downside.
I would like to try the Pirelli Scorpion AT/S but they don't come in the light truck tyre configuration and that is not much good to me as I go off road a lot.
I am constantly warned against using Coopers as they are supposed to have a lot of problems? but I don't know..........I think they are okay for black-top work.
There has been an awful lot of discussion on many forums on this subject.
For reliability and value it seems to come down to a choice between B.F. Goodrich  A/T  and Bridgestone Duellers, when considering general purpose tyres.
Do insist on the LT (light truck) versions if you intend to go onto rougher roads and/or carry a full load in the car.
-- Edited by Rolly on Thursday 5th of November 2009 07:11:47 PM
Cheers, Freddo
confuse
evileye Hin Guys, good to hear from you again .
Tyres !!!!!!!!!!!!!!!!!!
I'm in the same process at the moment ,
had bf A/T  goodrich on ,started off ok but the two rear faild at 30k .two weeks into lap around the block last year .Was not impressed ,further more Mt Isa had no stock ,
they had been six weeks & still waiting .
It was a warrenty claim so they supplied two BF M/T  .[mud terrain]
shocking combination , when loaded and uneven surface just can't keep it on the road
I will be glad to see them go .
The most complained about tyre on the road last year was the coopers ,they were suffering a lot of side wall damage , also very hard to claim on ,this was also stated by tyre dealers.
I'm am currently looking at the Micky Thompson [Dick Cepic] FC-11 .
Very similiar tread to the BF A/T . they are a 60/40 [black top /dirt].
Just put in Micky thompson tyres & you can see them ,cheeper than bf .
also look at the bf goodrich site ,read the complaints.
Bridgestone Aust. has gone bust as well .
-- Edited by justcruisin01 on Friday 6th of November 2009 07:36:55 AM
JC.
try the Bridgestone D694 L/T, I dont think you will be dissapointed, we sell a lot of these and have very few returns
we have regular reports of rough mileage in excess of a consistent 70,000 kilometres on and off road
they are a combo tyre good on road and off road!
What happens when the A/T's "fail"?
I've done more than 30,000kms, should I be worried?
Most of the time on black top, but I have done a few dirt kms as well.
I chose them because of the reputation at the time I put them on, and because I thought they'd suit everything I needed to do with my truck.
Are the Micky Thompson's ok for all surfaces?  Black top, mud and sand?
What's your experience.
Hi Granny,
The first tyre developed air bubbles in the side wall near the bead area, it ment the inner layer of sealing rubber had faild alowing air into the case .
The second one had a steel belt failer which lets the tyre bulge in the centre ,inturn wears through very quickleyexposing the belt & blowes out. I spotted this one while stopped ,tryed to move to a suitable place to change it  ,didn;t go two hundred mtrs.
Like you i went on reputation also , I think in their day yhey were ok but now they are old tecnology .
Go to the  BF Goodrich site & have a read .Also the micky thompson site , tyres,FC_11
check report by Ron Moon .
I knew him years ago before he started tours & wrighting ,he was in the Tamworth 4x4 club.
I have spoken to several tyre dealers ,all spoke highly of these .
I will be fitting a set in the next couple of weeks.
There are several styles available , the FC-11 is very similiar to the BF A/T .
they are a 60/40 tyre ,hwy/dirt .
Hope this helps you
Cheers.
PS. the remaining two have done 80k but very out of shape confuse
-- Edited by justcruisin01 on Friday 6th of November 2009 07:42:53 PM
JC.
Thanks heaps James. Forewarned is forearmed.
I keep a close watch on them and rotate them about every 10,000kms. Hopefully I'll cut some trouble off at the pass.
It sounds like Thompsons are the way to go. I'll do some reading. Cheers
Michellin 60,000 km on 100series cruiser towing 2,500kg van still gots heaps of tread. Coopers are rubbish.
