Post Info TOPIC: MOUSE BALLS...
MOUSE BALLS...
MOUSE BALLS...
I don't know how they wrote this with a straight face. This was a real memo sent out by a computer company (IBM) to its employees in all seriousness.  It went to all field engineers regarding a computer peripheral problem.  The author of this memo was quite genuine. The engineers rolled on the floor!  Especially note the last couple of sentences...
To: Whom it may concern
Re: Replacement of mouse balls
If a mouse fails to operate or should it perform erratically, it may need a ball replacement
Mouse balls are now available as FRU (Field Replacement Units).  Because of the delicate nature of this procedure, replacement of mouse balls should only be attempted by properly trained personnel.
Before proceeding, determine this type of mouse balls by examining the underside of the mouse.  Domestic balls will be larger and harder than foreign balls.  Ball removal procedures differ depending on the manufacturer of the mouse.  Foreign balls can be replaced by using the pop off method.
Domestic balls are replaced by using the twist off method.  Mouse balls are not usually static sensitive.  However, excessive handling can result in sudden discharge.
Upon completion of ball replacement, the mouse may be used immediately.  It is recommended that each person have a pair of spare balls for maintaining optimum customer satisfaction.
Any customer missing his balls should contact the local personnel in charge of removing and replacing these necessary items.
Please keep in mind that a customer without properly working balls is an unhappy customer.
Merda tauris scientia vincit
Oh! Yeah!
Ripper!
Pam
they must have been too engrossed in writing this to really read what it says.
this is hilarious.
From  NSW
Good One Jim!!
The real stories are often the best :)
Daisy and Disco Duck
Adelaide South Australia
Gotta Think Outside the Square!
Now that food has replaced sex in my life, I can't even get into my own pants.
If at First You Don't Succeed.......Redefine Success !!
