Post Info TOPIC: towing behind a motorhome
I would like some advice on towing a car behind a motorhome. Thinking of buying a 3 door suzuki vitara and possible using an A Frame set up. Any advice etc would be appreciated
cant see any problem (except the obvious, not able to see it, parking and overtaking) towing with a motorhome
if you could, it may be better to use a car trailer and the extra space put to good use with very little extra size
Cannot store a trailer at home due to space constraints, hence the other options. Motorhome is based on an Iveco Daily 50C18
well I cant see any problem towing the suzi, "A" frame would be fine, just check on the legalitys, weight restrictions of the motorhome towing capacity rating
"Everybody's doing it, doing it,
Everybody's, doing................." winksmile
There are quite a few folks out there with vehicles on "A"-frames.
The 'Jimny" has been a popular choice for quite a few years.
As dave06 says, you'll need to talk with your traffic authority.
-- Edited by Rolly on Sunday 28th of June 2009 07:36:35 PM
You should have no worries with the A frame and the suzuki. I would go for a tilt a trailer single axle, they can be reversed, where the A frame can not and don't take up much more room than a 6x4 trailer
Hammer
If buy a new suzie look hard at the diesel model well worth a serious look they were coming out some time back so should be out there now.
I'm with you, another trailer is just a pain in the rear end with rego's and pink slips etc, it just goes on and on then you need to store the thing and if on a normal van site your buggered for room Go A Frame
Welcome to Nomads Hammer. Thanks for your input on this query.
They're everywhere! They're everwhere!
See you out there sometime. Cheers Chris
Transport has no borders.
Thanks for the input so far all. I was not aware that you can't reverse with an A frame, hammer, for one. That could be a real hassle! Another thing I read that jimny's cannot be flat towed due to their transmission which was why I was thinking of the small vitara over a jimny [which was going to be my choice originally].
Have,nt reached that discision stage yet,
But if it legal for an A frame in Vic and QLD, and illegal in NSW, how do you get from A TO B ?
Mike and Judy
enjoy your sunrises,we only have a limited number
Another case for national laws, registrations etc.  Chris
Mike. I don't seem to be able to locate a specfic  road rule in NSW that makes A frames illegal , any idea where I could locate it  .
Back in 1999 NSW RTA put out an extensive guide on A Frame Towing  and a comprehensive check list which is still on their website .
You'd have to double check . . but I understand that towing with an 'A' frame is also illegal in WA
Mike
The Grey Roamer
Tip-toeing Through Paradise
thegreyroamer.blogspot.com/
"You'd have to double check . . but I understand that towing with an 'A' frame is also illegal in WA."
I think not.
Back in the 1970's the then RTA refused to contemplate the concept, without any justification whatsoever, but I do believe that a few persistent individuals got the relevant Minister to shake them up a bit.
