Did any one see this War On Waste episode about water.
I worked in the food processing industry. I remember (20 years ago) one of our Micro Biologists being asked, Would not Bottled water be better than the Town Supply for our product. He answered that it did not come up to the standard required by the food industry.
UV works well also , with sediment filtering prior , and fine carbon filtering after uv treatment , we've been using this type of system at home for years for our tank water
As a side note our son used a portable " camelbak" 1 litre uv unit when he did Kokoda and worked well , my daughter took same unit to Vietnam and no worries there too .... seems to do the trick :)
-- Edited by kesa32 on Tuesday 18th of September 2018 09:03:38 PM
UV works well also , with sediment filtering priort , and fine carbon filtering after uv treatment As a side note our son used a portable " camelbak" 1 litre uv unit when he did Kokoda and worked well , my daughter took same unit to Vietnam and no worries there too .... seems to do the trick
Wow Kesa, and they didn't add Chlorine, simply amazing situation, unbelievable in fact!!
Chris & Sharyn.
Mitchells Island. NSW.
2016 D-Max, 2012 Jayco Sterling, 1 dog, wife n me.
There is another option if we don't use these "poisons" eg chlorine & fluoride in the way that we're instructed to for our continuing good health. It is not pleasant & this forum would be down one or more members!
I saw that Kooka's company recommends it for rain water tanks!
I lived in Adelaide for 21 years, Ceduna for 15 & only drank rain water - UNTREATED! The tap water was terrible! The biggest hazard we faced at Ceduna was mice (in the mice plagues) getting in the tanks, forcing us to empty the water. When I moved to Darwin in the late 60s, the tap water was not treated but someone with "brains" decided that birds could poop in the water & it had to be chlorinated. So they added chlorine (by the ton we thought) to clean out the pipes, etc - you could smell a running tap from 10m away!!
What happened to the old solution of adding raspberry cordial to the caravan tanks?
Don't fret kooka (I don't know ya name coz you fail to provide it) but all interactions between folk will elicit other's opinions which, most often, will be as strongly rooted as your own.
Hang in there, give this mob some time and you will find the 95% of us are almost human and often respond with our own opinions from experience.
Ya'll git used to us.
I offer the following -
opinion
1. a belief or judgment based on grounds insufficient to produce complete certainty. 2. a personal view, attitude, or appraisal. 3. the formal expression of a professional judgment. 4. the formal statement by a judge or court of the principles used in reaching a decision on a case. 5. a judgment or estimate of a person or thing with respect to character, merit, etc.
opinionated
Holding stubbornly and often unreasonably to one's own opinions.
Cheers - OH and welcome to the forum - it's been an interesting week - John
2006 Discovery 3 TDV6 SE Auto - 2008 23ft Golden Eagle Hunter Some people feel the rain - the others just get wet - Bob Dylan
Here's an example to help you understand https://ww2.health.wa.gov.au/Articles/U_Z/Ultraviolet-disinfection-of-drinking-water
Ultraviolet is a viable method of making water biologically safe, but the power consumption required is typically too much for most RV situations. Reverse osmosis has the same draw back.
Many other chemical biological controls work too.
Chlorine treatment is the most common method world wide and is very cheap and very effective.
Most methods benefit from final filtering using fine active carbon filtration.
Cheers Peter , yes they have to be left on 24/7 for longevity of the globes in a home sized system , ours runs a 14w uv globe Agree chlorine is a cheap viable solution for killing the nasties and dissipates quickly , was just putting uv out there as another solution :)
Forgot to to add , our home system is an under sink triple filter job and serves just one standalone tap for drinking water
A full size complete home system is obviously much larger
-- Edited by kesa32 on Wednesday 19th of September 2018 09:56:16 AM
-- Edited by kesa32 on Wednesday 19th of September 2018 09:57:45 AM
Indeed UV is used in some areas for tap water purification a friend who works in the water industry informs me.
The major problem with UV for our application as I see it is:
1 - Power consumption, as Peter mentioned
2 - It really needs very well filtered water to give the UV a chance of getting to all the bugs. Given that e-coli is 0.5um long and viruses may be only 25nm they don't need much particulate in order to be hidden from the UV. I see UV as being really useful for things such as Asian tap water purifying.
Chlorine is still, by far, the best way to kill most bugs (NB. although not Cryptosporidium and Giardia) and both the scientific evidence and common sense experience over more than 100 years support this assertion.
Yes, chlorine breaks down and disappears quite quickly, that is a plus, but also a down side because after it has broken down, the protection ceases.
The rate of break down is increased with poorer quality water and with higher temperatures. The water in RV water tanks can become quite warm in many situations and that provides a great breeding ground for nasties, especially when there is any contamination in the water and even in complete darkness.
We always re dose our water with a full compliment of new chlorine any time we pick up water and use extra chlorine if the water is at all suspect. Essentially, if you can not detect any chlorine by smell, there is probably not enough left, because it has all gone.
For those that think bugs will not grow in water in the dark, on at least 2 occasions the mid north of SA and the Peninsulas have had contaminated water emergencies with their piped drinking water in the summer when bugs have grown in the pipes between the Morgan chlorination and pumping station on the river Murray and the towns that use that water along the way. The authorities increase the chlorination concentration in summer to prevent this.
A good active carbon filter will remove any remaining chlorine (and lots of other stuff) after the pump and before the taps. They provide good tasting, safe water.
Hi Kooka thank you for your original post which I am sure many enjoyed just as I did. I am very much into the health scene, and like to be aware of what I consume, I also believe how we live and what we consume on the inside shows on the outside. I agree with what you said in your last Post, its been going on for as long as I have been a member. Thanks again, and I would be happy to see future posts from you should you be prepared to submit. Take care and enjoy what life has to offer, and avoid like the plague the other lol . Always with a smile.....Kisha
Hi Kooka, thanks for the post. Hydrogen peroxide is also great for cleaning your ears. 2 mils in an eye dropper or in this case ear dropper, dissolves wax and is safer than digging into your head with foreign objects. It crackles and bubbles as it dissolves gunk.
For those that think bugs will not grow in water in the dark, on at least 2 occasions the mid north of SA and the Peninsulas have had contaminated water emergencies with their piped drinking water in the summer when bugs have grown in the pipes between the Morgan chlorination and pumping station on the river Murray and the towns that use that water along the way. Peter
Can you provide some fact to back this up Peter, I do have a recollection of something in the very distant past, however can find nothing of relevance online.
As a matter of interest York Peninsula is provided with water via a pipe line from Swan Reach to Stockwell, not Morgan, completed around 1970.
It does get a little tiring hearing horror stories re SA water related by visitors, that for some reason South Australian residents don't seem to experience.
