Post Info TOPIC: Short 15amp leads
Short 15amp leads
Hi all,
Can anyone point me in the direction of a short (3m) 15amp power lead to run from my genie to my van to avoid coiling it up under the van when in use?
Are they even available ?
Searching only yields the usual 10-20m lengths .
I know I can make one easily enough but would prefer an off the shelf where 240v is concerned.
cheers Brett
-- Edited by denmonkey on Tuesday 6th of February 2018 10:12:00 PM
Any sparkie would make you one. I doubt you will find one "off the shelf".
Good idea. Coiling extension leads creates an overheating and fire risk.
Here is one www.ebay.com.au/itm/5-Meter-15amp-Extra-Heavy-Duty-Power-Extension-Cable-Lead-Cord-With-10amp-Plug-/222320429242
For a 4 metre lead try here : https://www.generatorplace.com.au/shop.html#!/4m-Heavy-Duty-Extension-Lead/p/57955444/category=18969019
Bill B
Hi denmonkey, can't answer your question exactly, but I had a sparky make me a short one with 15 amp plugs/ends and heavy 2.5 mm wire. It allows a Honda 2 gen to run the Ibis 3 aircon in plus 40 degree heat with no problems.
Cheers, John.
 That is legally and technically a 10A extension. The OP needs 15A plug and socket.
Peter, Yes sorry I didn't pick up on 10 amp plug - I normally use Generator place to purchase, but I just typed in short 15amp lead into Dr Google.
Safer ? https://www.ebay.com.au/itm/391826513035
Generator place is the way to go
 This is a 10A lead, again, and the OP needs a 15A lead and plugs.
I think you will need to get a longer lead cut it the required length and have two separate leads made.
Kebbin
I think a longer lead would be better. It will allow you to place your generator a little further from the van so you will get less fumes drifting into the van. The fumes can also include carbon Monoxide.
 AND the RCD  function is useless , when used with a  portable generator
Just as useless as the one in the van will be
 If you want to be safe from electric shocks to eartth ,Contact "https://www.rvdsafe.com.au/ regarding their plug in units for use with generators & inverters
-- Edited by oldtrack123 on Thursday 8th of February 2018 12:49:51 PM
Thanks everyone. I this one is a winner.
www.generatorplace.com.au/shop.html cheers BB
