Post Info TOPIC: Dune fridge freezer iceing up
Kam
Hello, has any body purchased a dune frontier 20lt fridge freezer purely to run as a freezer? I bought one and the seal freezes up after it has been opened. The next time I try to open it I have to force it open. It is used to store frozen food as a backup to my fride with a shoebox sized freezer so I only open it up occasionally to restock the shoebox.
If anyone has experienced this problem or can recomend a small fridge freezer that they used with no problems That would be great.
Cheers Ryn
msg
Have you damaged the seal perhaps?
Wol
I have same unit, never seen this. Mine is set at -10 deg C always. Maybe moisture on seal or lid freezing the two together?
regards
Kam
If the seal was damaged it happened the first time I tryed to open it. Or maybe it was damaged when I purchased it.
Thanks for the reply.
Kam
Thanks I will try it at minus 10, but it is not the safest temp for frozen meat.
With some space in the top, put a bright light inside and close the lid at night and see if any light gets out to check the seal.
Kam
Meat is perfectly safe at -10C for about three months - probably a lot longer.
When freezing, providing the temperature is below about -5C, food will keep well but for a shorter time than the standard domestic setting of -18C. I have always run my bush freezers at -12C in order to conserve energy.
There is confirming research on this if you doubt me - Google may find it.
