Post Info TOPIC: Lack of double glazing
6.9°C this morning in Sydney at our place. It's such a waste of energy & time mopping up water. Tomorrow morning it is supposed to be 5°C, & we have had this in previous years. So I am expecting even more condensation. Wish we had double glazing & thermal break frames. In Germany they use triple glazing. In Norway they are starting to use quadruple glazing.
Stop your heavy breathing or stop what is causing it. biggrin
Wawt, instal double glazing!
"When all is said and done, more is said than done"
Simeon Craik.
Much the same temperature here, also by the coast. No condensation.
What are you doing? Sleep better with the inside temperature a bit lower.
Heavy breathing, no such luck!
I'm in a block of units, double glazing unfortunately isn't going to happen.
If I leave the multiple layers of curtains open then there is no condensation, but heat flys out the window.
Heat loss for each degree difference in temperature per square metre of glazing is about:
85 watts single glazing
30 watts double glazing
12 watts triple glazing
7 watts quadruple glazing
So tomorrow morning at 5°C as suggested by BOM, if I want 18°C inside, there is 13°C difference x 85 watts = 1100 watts of heat going out through each square metre of glazing. Also include the aluminium frame as it is a better heatsink than glass!
Take a peek at Magnetite Double Glazing.
A couple of decades ago I vacuumed the roof space, to the nth degree! There was zero insulation. Fitted Air cell/Kingspan building bubble wrap under the roof tiles. An absolute sh!t of a job, especially getting down to the gutters, but I got the knack for it with a stick.
Then the ceiling got batts. I have since replaced all the batts (with better acoustic batts) as we had a rat problem. So many dead rats in the roof. They had also eaten the insulation off electrical wiring.
It is actually common area but the building wasn't going to pay for it. But since we had no intention of moving we paid everything.
We knew the previous owners & they said the Unit was freezing in winter & a sauna in summer. We moved in in summer & the heat was ridiculous. The insulation made a massive difference.
There are actually two templates.
 I have looked at that system.
The problem is, if there is any leakage of air between the glazing you end up with condensation. My sister in-law in Germany has one window which was damaged & the argon escaped.
I saw the condensation each morning, it would slowly go over the day.
A couple we know did a full reno a few years ago (the guy is a builder) and they went for maximum energy efficiency with help from an academic/expert from nearby uni. Lots of insulation plus the whole house is wrapped under the cladding and then checked for any leaks etc. They require only a fraction of the normal heating & cooling, and then only for very short periods. They imported triple-glazed windows from Germany to Australia for less than it would have cost for double-glazed from an Australian supplier.
msg
Do you have a gas heater?
My niece in Germany replaced all their double glazed windows with triple glazed windows.
Australia's glazing makes the stone age look like modern technology. It really is pathetic what we have here. The European windows & doors will both swing & tilt open inwards, for people who don't know. So easy for ventilation & cleaning windows.
Another benefit of multi layered glass, is improving acoustic qualities.
Our block of Units is electricity only.
We do have 3 phase in each Unit which was for the original Dux hot water systems, 17 in total including the 2 in the common laundry, of which about 12 Units use the laundry. The rest have their washing machine in their own Unit. Our common electricity bill for the block including laundry is $1k pa (will go up a lot with the new $1.66 daily fee). Many Units have replaced their 3 phase with squeezing a 50 litre tank in the kitchen cupboard. A bit small but what else can one do in a Unit, generally not enough room for two 50L tanks! A small tank has a daily 24 hour period heat loss of about 1.7kWh. Stainless tanks are a bit better.
No solar in the block. We would really need to replace the 1950s roof tiles first, ~$100k.
We do maintain the block properly & have $200k in the Sinking Fund. But want that money available for major repairs. They have happened offen enough over the 4 decades we have been in the building!
