Post Info TOPIC: HWS temperature
HWS temperature
I have the usual Suburban HWS in the Jayco.
The temp of the water wether on gas or water is only 47-48 C.
It's not hot enough because when showering too high a percentage
of hot has to be used with some cold to have a decent shower. My old
Majestic is near 80 - which means that less hot has to be used to
temper the cold so a decent shower can be obtained before the hot
runs out.
What can i do to up the temperature?
cuss2.gif. B
-- Edited by Brodie Allen on Thursday 26th of March 2026 04:40:44 PM
A HWS temp of 80C seems somewhat excessive.
Apart from the energy required to achieve and maintain that temperature there are legal requirements for domestic & commercial Hot Water Systems :
The Plumbing Code of Australia and relevant Australian Standards set strict temperature requirements for all hot water systems.
Plumbers must set storage temperatures to at least 60°C to control the growth of Legionella bacteria. For personal hygiene useslike showers and bathsthey must cap the delivery temperature at 50°C to prevent scalding.
In commercial settings such as kitchens, plumbers may set delivery temperatures higher, up to 70°C, for sanitary purposes.
Always include an approved tempering valve in new installations. Make sure that hot water doesnt exceed 50°C at outlets used for personal washing.
-- Edited by kgarnett on Thursday 26th of March 2026 05:18:28 PM
I have a Truma in my motorhome and it has the option of either 60 or 70 deg C. I always make a point of rinsing the shampoo out of my hair first, just in case I run out.
JG pipe is likely to fail at or over 70C.
Brodie,
My Jayco has a temping valve, does yours? If so, maybe an adjustment of that valve might help adjust the temperature at the taps.
I spent 3 months in Germany with my relatives. Their HWS is a heat pump system in the basement. It has 3 settings, 45, 50 & 55. They have it set on 45. The bathrooms are 2 floors above, never once was the hot water not hot enough. I always needed to add cold water. Ambient outside temperature was typically -5 to 0 degrees while I was there December to February.
I learnt quite a few cold weather skills while there. I have been there many times before but only once in winter before briefly.
The central heating system is always left on level 1 at a minimum over winter so pipes don't freeze.
Once I tried to clean the car windscreen with water. It didn't matter how much water I put on the windscreen, it just all froze into solid ice. Which was actually impossible to scrape off.
If I had simply scraped it off initially with the windscreen ice scraping tool, it would have been easy, like I had done previously.
One lives & learns new skills in a cold environment. We were grateful that even though it was so cold, that we only had snow, but no rain! The rain freezes on the roads which turns them into a skating surface.
I recall our house HWS is set to 50 degrees (safety reasons)
I Have done this ...and with common sense works well...just remove the tempering valve. The HWS has a thermostat set at 65 degrees so all the fearmongering about getting scalded is just that. The upside to this is that less hot is used in the shower and 2 people can have two decent but shortish showers without running out of hot.
Find out how to do it ...enough info on the net...but is a simple easy job.
Cheers Keith
Nuthin is ever the same once I have owned it ......
