Post Info TOPIC: Awning Cover Installation
Hi all, about to add an awning cover for a little protection.
Just after a little clarification on the Sika Flex type to use for a fibreglass van and aluminium track.
Thanks biggrin
I Remember It ...............All Too Well
TAKE YOUR PASSION AND MAKE IT HAPPEN
 https://youtu.be/ILWSp0m9G2U
Status: Online
I would use 11FC for that.
Note that the aluminium sail track will expand and contract with changes in temperature (could be easily 50C from coldest to hottest) quite a lot more than the fibreglass, so the Sikaflex needs to be quite thick, maybe 2mm at least, between the track and the fibreglass otherwise it will tear.
You can do that by using small patches of double sided adhesive foam tape folded to get the thickness. It will also hold the track in the right spot while the Sikaflex goes off.
Surface preparation needs to be really good.
Sikaflex 11FC
Thanks very much for that Peter, and the xtra hint on double sided tape. I have been wondering how to deal with holding in position .
very much appreciated.
Ineedabiggerboat wrote:
Sikaflex 11FC
 Thanks
Would you use the 11FC as well on an aluminium track on aluminium sided van?
Status: Online
 Yes.
Thanks Peter
