Post Info TOPIC: Portable Refrigerated Aircon
Has any member had experience or purchased a portable camping refrigerated aircon similar to the Kickass 400w free standing or under bench types. Eg...
KickAss 240V Portable Air Conditioner for Camping - 400W KickAss Products
Temu | Explore the Latest Clothing, Beauty, Home, Jewelry & More
 Sanjo 2200W Under bunk Reverse Cycle Air Conditioner | Cool-J | Caravan RV Camping
Any experience opinions would be appreciated.
Cheers, Richard (Dick0)
 It's junk.
I see Kings now have a similar product.
Portable Air Conditioner - 4WD Supacentre
That's junk too.
Think of this the other way around - that may be easier:
It's -2C outside your caravan - would you buy a 400W fan heater to keep you warm?
I am far from recommending one of the Kings units but suggest your example is not quite right.
The power draw of an air conditioner is very different from the output. The promotioinal specs show 600 watts power draw, while further down it says 600-900 watts. Which is it? However the specs say 5100btu output, which is about 1500 watts. If heating, that would be reasonable for a caravan fan heater.
My van has an Ibis rooftop air conditioner rated at 3.2kw output, and it does a good job. An air conditioner with less than half that capacity, as with the Kings would help, but probably only drop the temperature a little. The losses due to the ducting would be part of the reason, coupled with the difficulty of exhausting the hot air outside.
Parked in the shade, or at night maybe it would be OK but in my opinion not much good otherwise. I did not see any specs on noise levels, which is pretty important in a small space.
Also, with air conditioners, the hotter it is the less well they work. This one has a pretty low efficiency (600 watts to produce 1500 watts) which is on the low performance side. Maybe on a baking hot day it would still try to produce that 1500 watts of cooling, and that is when it ramps up to 900 watts. Note the quoted startup power of 1200-1800 watts if intending to run from an inverter. But you would need some pretty substantial battery capacity.
-- Edited by Are We Lost on Wednesday 18th of February 2026 06:21:01 PM
Thank you for comments so far.
I am wondering whether anyone here actually purchased a portable or under bunk refrigerated air conditioner.
I have seen reviews on YouTube of portable and under bunk types and wish to compare with personal experiences from Members here.
If/when my OEM roof-top caravan AC fails I shall purchase one of these or similar - don't prat around with junk, it'll cost you a fortune and won't work well:
Mitsubishi
Mitsubishi
How efficient will that be sourced from the onboard batteries?
I imagine it is one of the more efficient air conditioners on the commercial market within its price range.
This is physics. It requires X energy to cool your caravan and if your batteries cannot meet that then you need more batteries and a way to recharge them - end of story.
Some piece of cheap Chinese junk will not defy the laws of physics.
-- Edited by BBN2 on Thursday 19th of February 2026 07:53:32 PM
