Post Info TOPIC: Water Hammer Arrestor.
Hi..there doesn't seem to be a search engine so rather than read the 350 pages here in "techies corner" may I ask for advice directly. I'm trying to alleviate the knocking sound when the taps turn on. I understand I can install water hammer arrestors and believe they out to be on each pipe so I'll need 6 in total. AA (mini) arrestors for 3 utilities. Kitchen sink, most importantly. Bathroom sink and shower. I've found them at Bunnings for about $70 each but AliExpress have the same stainless steel AA arrestors for about $7 ea. I understand the Aust stand water pipes are 12mm so I'm thinking to buy 6 arrestors from AliExpress and I'll need 6 "T' connectors to place them inline the pipes. I like the look of the "quick connectors but am unsure as to whether the AA mini arrestor just screws into the 'T", (also avail AliExpress) Any advice greatly appreciated!
Hi Peter,
My understanding with pipe hammer is when you turn taps off fast (ie with the modern lift up-push down taps). Is your question relating to a house or a van, motorhome? I haven't experienced it with our van yet but since having a new kitchen installed in our house, it does occur when my other half cannot remember to turn the tap off carefully.
I installed an anti-hammer device where the cold water feed came into the house - it certainly reduced the hammer effect on all outlets but when the plumber replaced our HWS, he removed it. I certainly need to get it reinstalled again.
There is a "Search" on this forum but it is limited & for some reason it has lost some of its effectiveness.
Are we talking about a house? Water hammer is a funny thing. I started with a pressure reducer at my water meter as we had a water pressure reading of 700kpa. Houses should be around 500kpa so I'm told. A mate up the road got a new hot water unit installed and in a very short time it blew up, apparently from over pressure. A lot of new appliances don't like over pressure now. It wasn't covered under warranty because of the pressure. He had a reducer installed at the meter. Don't know why this wasn't done with the new installation. After our pressure reducer was installed we didn't like the pressure the water ran at and it didn'tfix the problem. Walking the dog up the road and my mates neighbour was having getting a reducer installed, I stopped and had a chat to him and as he was installing a variable pressure reducer told him to stop off down the road and I'll have one. So reducer mk2 went in, but pressure setting was not changed. Didn't fix the hammer either. So off to my hot water system. There is a flow valve (I'll call it that) on the hot water system. After a few years this can cause water hammer to be produced. Got that changed and the water hammer was gone. It does also depend on how fast you turn the taps on or off. It didn't matter if cold or hot tap was used. Also we got water hammer with the dishwasher and washing machine. All that was fixed after replacing this flow valve thing.
Oh, in the end I didn't change the pressure setting, we just got used to it.
-- Edited by Corndoggy on Saturday 14th of February 2026 08:43:15 PM
A long time ago I had a house where I got water only when the kitchen taps were used. A mate said change the washers on those taps. I did. It worked.
Water hammer can commonly be due to an airlock whether it be in a van or a house.  Open all taps starting from the lowest and furthest, also flush the toilet or toilets a number of times.  Let it run for a couple of minutes and then from the furthest taps work backwards turning them off.
Tim
If you are talking about your home, a simple solution for water hammer may be to partially close the main tap at the entrance to your property. That's what our plumber did for us and it has worked well.
I think it was Dorian a few weeks ago mentioned use the "" with the search engine and it works a treat.
I had severe water hammer at home for a few weeks, it was driving me crazy, so I did the turn the water off at the mains and close them off in the recommended order.
That didn't work.
So I changed the washers in what were the two highest water taps that seemed to be the main offenders and it worked a treat.
The old washers were a bit worn in parts and must have been allowing air to get into the system or the water running backwards or something to that effect.
Dunno - but the effort by changing the washers seemed to work in this instance.
I have had the same problem with the plastic light cheap tap washers they flutter up and down when on causing water hammer .Most new taps have the plastic tap washers from new .My brother in law is a plumber and he told me to always buy the heavy washers with metal shafts as the heavier washers don't flutter up and down when the water runs. Always fixed the water hammer for me .
To all: Thank you for your comprehensive replies. I apologise I wasn't clear that I am only talking about the caravan. It seems all taps create the hammer sound. I'll try the suggestion to turn all taps on from the lowest (assuming the tap on the drawbar, then bathroom sink, kitchen sink and shower and flush loo a few times), thanks for advice Tim. I'm probably sold on the idea of installing "AA mini arrestors" on all pipes except drawbar tap cos it's hardly used. I'll find out if hot and cold both need arrestors from the retailer. I now need to find the best "T" connectors, I'm favouring quick fit connectors for 12mm pipes which is apparently the Aus standard. (I'll check with callipers first) I did notice a Bunnings mini arrestor is about $78 whereas the same looking one from AliExpress stainless steel so not rubbish is $6 odd plus postage $7. I'll need 6 so a big saving. I'll check with my local friendly plumbing shop first and am able to do the work myself. All pipes seem easily accessible but I haven't checked the shower yet. Ty for the kind responses. If anyone thinks I'm doing the wrong thing I'd appreciate your advice.
Peter,
Does the water hammer occur both off-grid, ie: when using the on-board water pump, as well as when on mains pressure? And if so, is it the same intensity on both? Did it always happen or is this a new development?
Don't know how much experience you have with caravans, but for first timers a noisy on-board water pump can sound like the plumbing is shaking itself to pieces.
My van has a pressure limiting valve in the mains water inlet which is something you could look at. If the problem is only on when on mains pressure that would mean only fitting one device instead of six.
If it is on both mains and water pump then maybe the pipework needs more support or saddles to stop movement.
Fitting six mini arresters seems a bit drastic. I don't believe water hammer in it's true form is a very common problem on caravans. I may be wrong.
Let us know whether it happens all the time.
Robert
Peter,
You list yourself as a Newbie. How long have you had the caravan? Bought New or Used? Has this "water hammer" sound always been apparent since you bought the caravan? My pick is that it is probably just the your on-board water pump doing its normal job. These pumps can sound noisy particularly if mounted under a seat/bed or in a cupboard that can act as an echo chamber. The pump should be mounted on anti-vibration rubber washers.
Robert...yes the hammer noise seems to be most noticeable under mains pressure. When we first got this 2nd hand van the water was fine then I discovered it was running as if it was off grid. (Oddly a friendly camper who was also a plumber couldn't diagnose the problem.) Then someone told us about the Pressure Limiting Valve (PLV) and when I got home I disassembled and lubricated it and the mains pressure worked ok except with the added hammer noise. I do like very much the idea of only installing one thing at the mains inlet. Does my new information alter your advice? Thanks.
Perhaps Bald eds suggestion of anti vibration washers is the answer? Btw it's a 2016 new age OZ20ES2 and we are super happy with it. This is our fourth van. I only meant I'm a newbie to Gray Nomads.
Or perhaps the pressure limiting valve isn't functioning correctly and cld be replaced?
Peter, I assume we are talking about flick mixer taps. If that is correct they don't have traditional washers as such.
Does it matter at what speed you turn the tap off?
Is it the same regardless of whether the hot or cold water is on? If it only happens on one, then that is half your problem solved. If it is on both, then start looking for areas where the pipes could be vibrating against walls, cupboards or the chassis of the van.
With a helper you should be able to determine what area of the van the sound is loudest. Start looking in that area. As for your "friendly camper" plumber, maybe he wasn't that interested in helping.
Good luck.
Robert
Personally, I would do the airlock procedure first and as Thomas stated look for loose pipes that vibrate when you turn the taps on or whether the vibration is happening in the taps themselves which could indicate the tap valves.  Any replacement of equipment should be secondary. Residential plumbing pipes are secured, or should be at regular intervals, RV plumbing tends not to be.  As you say it happens on mains pressure then perhaps one of these adjustable valves may be of benefit. Have you tried turning the tap down at the main connection which will not reduce the pressure but will reduce the volume of water flowing into the RV system.
This is just an example not a recommendation.
 https://www.ebay.com.au/itm/376771822345?
Good luck
Tim
-- Edited by TimTim on Wednesday 18th of February 2026 11:09:23 PM
All good advice. I will begin the process of elimination. Thank you people.
