Post Info TOPIC: Where to put a UHF Antenna on Mercedes Sprinter
I've been using a handheld Uniden with a mag mount antenna on the roof for a while.
The radio sits on the shelf above the sun visor and I have a handset on a velcro loop next to it.  Not great, but it works.
I'd like to get a "proper" radio install done but am struggling with where to mount the Antenna.
Don't want to drill holes in the roof really.
Any other options would be appreciated.
A bonnet mount?  Where would I find one of those?
No bull bar or nudge bar to fit it on and no plans to add one.  (weight issue)
Rob
The best place is in the centre of the roof. Lower will risk a "shadow".
Go to a Jaycar shop.
Z brackets etc. is what you ask for. There is a range of variations.
Once seen, one can manufacture from aluminium angle, if clearances permit.
I use an Windscreen Aerial, similar to below on our Sprinter
www.ebay.com.au/itm/196293776616
If you go to a metal fabricator/engineering shop in the typical industrial area, phone first to see if they do aluminium. They all have an offcuts bin, so you can usually find a few small pieces about the right profile. Cheaper than those big hardware stores.
Good tips, many thanks
Rob
msg
 x2   I have a high roof Transit van
The best spot for an external aerial is where Peter_n_Margaret suggested.
With the absence of a bull bar, the next best is the Z mount on the edge of the bonnet.
Be wary that there are several types of aerials too. High gain ones (6-9dB) tend to have a narrow signal path; I recall the 3dB gain ones tend to be the most used, giving a wider but slightly weaker transmit/reception path.
I use zero or 1db gain antennas on the OKA. They are short, cheap and almost indestructible.
They give the clearest transmission and reception for a shorter distance (10km instead of 30km, as a comparison) and work better on undulating and hilly terrain.
I don't want to hear every tourist or truck for 30km in every direction.
