Post Info TOPIC: Replacing Front Widow on a Jayco Stirling
Any thoughts on replacing the wind out front window with a fixed window.
I'm reluctant to attempt to do the job myself, but over the wet season during heavy rain Im not sure if the water was leaking in around the window frame or the wind out portion was not sealing properly.
I'm leaning toward having a new window made with a heavily tinted and reflective polycarbinate with a new aluiminum frame. I suppose that I need a specialist manufacture because of the rounded bottom courners
www.ozvan.com.au/caravan-windows-and-window-protectors/fixed-caravan-windows/fixed.html
I am putting scratch resistant polycarbonate in all the standard, commercial windows in my new build OKA. It is a fairly easy process that takes an hour or 2 each.
Fitting the window to the van takes a few minutes..
Sorry I only just noticed your query -
PnM's solution is not as straight forward as suggested by Peter. Any front window is likely to leak, normally forced in by forward motion into wind. It is most usual to leak under the silicon caulking rather than the window gasket. Get some rubber tape (www.temu.com/ul/kuiper/un9.html~j-dfb30332~f-7f547e1b&_x_ns_product_id=1342919-17592590102809&_x_ads_sub_channel=shopping&_p_rfs=1&_x_ns_prz_type=-1&_x_gmc_catalog=1342919&_x_ns_sku_id=17592590102809&mrk_rec=1&_x_ns_catalog_id=1342919&_x_ads_channel=bing&_x_gmc_account=3544489&_x_ads_creative_id=82601188814561&_x_ns_device=c&_x_ads_account=176188701&_x_ns_match_type=e&_x_ns_msclkid=651f7254f38c188bcc7e1a79f79e51e1&_x_ads_set=521221344&_x_ns_source=o&_x_ads_id=1321615369961832&msclkid=651f7254f38c188bcc7e1a79f79e51e1&utm_source=bing&utm_medium=cpc&utm_campaign=BING_ADS%3A9069D888A1622112405DAA859F1D07B8&utm_term=4586200445085230&utm_content=BING_ADS%3A9069D888A1622112405DAA859F1D07B8
It will sealthe offending area around the window permanently.
Sorry for such long link I couldn't reduce it.
 Well yesterday I washed the front of the van and there wasn't  any apparent egress of but  the front kitchen bench was saturated.
This morning I washed the front section on the roof, there was some egress apparent from a side window.
Next step is to remove that window and reseal it, and I picked up tub of Ormond waterproof membrane to seal the front section of the roof just in case pin  holes in the roof are the cause.
I would use a good quality polyurethane sealant something like Sika Pro which is available from the big Green shed. I did a lot of testing with various sealants on aluminium to various substrates and for sealing windows into openings the higher grade urethane were the best. Many of Perths curtain wall systems on high rise buildings are sealed to the building fabric with one of those products. Sika Pro does not need priming provided the surfaces are very clean so pull the window out of the opening, do a really good clean up finishing with methylated spirit and then reseat in a good bed of Pro.
Greg O'Brien
Be aware though that many sealants and in particular silicones, are not compatible with most plastics and will part company with them in reasonably short order.
Greg O'Brien
 A great roof product was Ormonoid Silver Shild but its no lomger available, it appears Sika has taken over some of their products. So I will be using Sika's Ormonoid Bitkote No3 trailing it on the fromt meter of the roof.
-- Edited by Gundog on Thursday 22nd of May 2025 05:58:51 PM
I see nobody has yet provided a solution for replacing the front WIDOW
Bob+Deb
 First reply.
Peter_n_Margaret wrote:
 First reply.
 Window yes, WIDOW no.
Bob+Deb
Have a look at this. https://youtube.com/watch?v=cH7c6AtwYbo&si=omfTvOKoVCsbXTCc
Scroll down to how to reseal, replace windows. https://dicorproducts.com/videos/
Finally found a company that can make a replacement front window for my Jayco.
AJ Plastic manufacturing in Geebung Qld can make replacement windows.
biggrin  biggrin
I was wondering why the widow was at the front???
Sarcasm is wasted around here by the look... smile
-- Edited by Burt65 on Saturday 19th of July 2025 01:00:45 PM
Stop the planet.. I want to get off..
