Post Info TOPIC: Diesel Heater Glow Plugs Differences?
Any difference between the 2kw, 5kw and 8Kw Glow Plugs , looking at a back up for my 2Kw unit, just in case need a change in the bush.
https://www.aliexpress.com/item/1005006856088180.html
Had mine in since 2007 and solar had no glow plug issue. My thought, when do you need spares
Neil
Had trouble starting the heater in remote Bush, changed the Plug and the screen all good. Most likely it was a screen clogged problem. Just wanted the problem solved, hence the 2 changes.
Run some kero in your diesel once in a while. It tends to stop them sooting up. I add about 250ml to 5 litres of diesel.
Greg O'Brien
