Post Info TOPIC: Jayco Sterling Front Window Cover.
We have an issue with the cover when fully open it allows too much heat/light in, my partner prefers the opening to about a third op which needs something to restrict the amount the cover opens (currently use an occy strap),
So what's the solution ?, a different length gas strut if so how do decide the location and angle for the strut.
Is there another alternative
I thought all Jayco vans have these for boot and window protector.
They come in different lengths depending on the size of the protector.
Mine, for instance, are 300mm (extend to 600mm).
They are cheap to buy, usually come in pairs and effectively adjust 0-100%.
200mm Caravan Window Shade Stay Camec Boot Stay (Pair) 016420 Jayco | eBay
Cheers, Richard (Dick0)
Status: Online
The rear window of our vehicle. It can be fully open, fully closed or anywhere in between.
Operation is from inside.
youtu.be/L2EOrguTzZk
-- Edited by Peter_n_Margaret on Sunday 19th of January 2025 11:44:15 AM
The earlier model, Jayco Westport, use a pair of brackets/arms with sliders that have locking screws to fix the cover in position.
Could be purchased from Jayco & easily fitted.
-- Edited by Cupie on Monday 20th of January 2025 10:49:21 AM
 Thank you
