SmartBar Camp Creative
Post Info TOPIC: Anderson connector corrosion
Hi, just wondering what caused the old anderson positive connector to corrode.
It's connected to the AGM in the van so is live.
As it was crimped on I was able to manipulate the connector and get the wire out. There was no sign of gunge on the wire so I tidied it up, tinned it and soldered a new lug on.
Classified R.E.D. = "Retired & Extremely Disinterested" (Locksmith)
Hi 67HR,
Did you check the contacts of the Anderson plug of whatever you normally plug into it to see if it is also pitted/corroded?
To me it looks like it has arced due to a bad connection.
Robert.
That is electrolysis, it can be caused by damp dust, salt, seawater, sea air or a number of things that allow electricity to pass back to the earth. The earth that its passing to can be any connection to the vehicle that goes back to the battery.
thomas01 wrote:
Hi 67HR,
Robert.
 Hi Robert,
The vehicle connection is fine as I fitted it new about 20 months ago. The van is 13 years old so not sure how  long it's been on the van. It was green when I got it but had cleaned it up.
Cheers trev
 Thanks Rod, I thought as much as the negative connector is fine.
I've only had the van 20 months and the vehicle connection is all new with the earth grounded to the body not the battery, the van drawbar connector goes to the shunt (negative) then into the battery.
I'll be sure to monitor it and see if "greens" up again.
Thanks, Trev.
Just give it a wipe over with some di-electric grease. Only needs a very thin film. It can pick up dust, a dust cap on the plug will help.
 Thanks for the info Rod.
