Post Info TOPIC: Water pressure problems
G'day new to forum I hope someone may help we have a concept innovation having problems with pressure when connected to mains water about five minutes in the water pours out of the plastic drain valve under van I've replaced the drain valve, replaced brass pressure reducing valve, replaced plastic water reducing valve still having problems when connected to mains water maybe someone has has the same problem if so please help cheers headly.
Hi Headly
I am a Concept owner, ours is a Vision 2012 model.
Now is that water running out the water heater valve?
Will water come out of your system when you are using your water tanks and pump only?
Just trying to get an some idea of your problem.
G'day radar this is a 2021 concept water is coming out of the plastic drain valve and not the valve on the hot water tank .works fine on pump and tanks cheers headly
 Having a bit of a problem understanding about the drain valve.
Could we get a photo?
Perhaps a leaking check valve is allowing mains water to fill the water tanks and overflowing through the tank breather vent.
