Post Info TOPIC: AL-KO wheel nuts
AL-KO wheel nuts
Anyone know the size off wheel nuts for AL-KO 10 six stud Landcrusier electric brake drums ?
Just take one into any auto store, theyll size it for you.
 Insist on Hi Tensile bolts.
B
Bugga - didn't realise you were after nuts, not bolts.
They still need to be quality metal - there's a lot of torque on them if properly tightened
to correct specs.
B
Not only the thread has to be correct but the seat has to match with differences between alloy and steel rims, tapered or flat so best to take a nut with you for correct sizing, Cruiser pattern usually just relates to the stud pattern not necessarily the stud sizing, Cruiser's have a couple of thread sizes as well so could be M14 or M12 or other sizings ............ get one sized to save lots of hassle, like bearings best to check whats actually fitted than take someones elses van size.
I have used this mob quite a few times to order good quality wheel nuts especially when they are hard to find and they are certainly cheaper than most shops even with postage .... www.niceproducts.com.au/ .................... they are the supplier to many auto parts shops.
