Post Info TOPIC: Light bar
Light bar
Hi team, best/easiest place to tap in to loom for high beam for light bar on Colorado 2015.
rs wiseman
I always just tap into a wire at the back of the headlight, use a test light to identify the high beam wire, and use that as the trigger wire for the relay.
If your car uses HB3 globes for example they only have one filament, so you need to take the feed off the high beam shutter. Probably with a micro primary relay powering a secondary relay or you will end up with a computer error on the car. A bit more painful with modern cars like my 2013 car.
You can get adaptor cables for some vehicles, which avoids the need to tap into the wiring.
Greg
TAG Overland
Greg
TAG Overland
Welcome to the Forum, Greg - good advice.
-- Edited by Possum3 on Monday 19th of August 2024 01:10:20 PM
Hi mischief,
I attempted to do it on the cheap & tap into the headlight wiring - BUT Isuzu don't add extra wire for the buyer's convenience! I lost some skin, lots of hours trying to do it so I bit my pride & bought a Stedi adaptor - the job was done in minutes!
Still can't see how they could justify $30odd, though.
You can get these adaptors at most auto parts shops these days.
